Replacing Tail light issue.
Old Oct 1, 2015 | 03:30 PM
350z82's Avatar
350z82
Default Replacing Tail light issue.
I've been surfing this site for awhile now and I finally had to create a account so I could see about getting help with a tail light issue.
I have an 06 350z base model and I want to replace my tail lights due to bad seals and them filling with water. So, I ordered lights from a website that what advertised lights that would fit a 03-06 350z. When I went to hook them up, the plug was different. I was under the impression that 06's all had LED tail lights, but I guess that is not the case. I have seem on some sites that not all 06's have LEDs but it seems I couldn't find enough evidence to completely confirm this. I have attached a photo of the lights, the red is my OEM and the black one is the aftermarket one I purchased. Any help in explaining what I am misunderstanding would be greatly appreciated.
Old Oct 1, 2015 | 03:53 PM
dcains's Avatar
dcains
All '06> cars did have the LED tails. Not sure what you purchased - are they LED's, or not? If the ones you had on your car are OEM, and they're LED, I'd try and find the leak(s) and seal them. Never heard of the OEM lights leaking, though, so maybe they're not original to the car.
Old Oct 1, 2015 | 03:58 PM
350z82's Avatar
350z82
The Lights i purchased were stated as LED.
This was the one I purchased that was listed as LED ^
This is the one that came out of my 06. ^
I have seen this type of plug before when I search for OEM 06 tail lights. just Not sure what is up w/ the plug.
Thanks for the help, this has me so confused.
Old Oct 1, 2015 | 04:02 PM
dcains's Avatar
dcains
But, are your original lights LED, or not?
Old Oct 1, 2015 | 04:03 PM
350z82's Avatar
350z82
I was assuming LED as it is a 06. Apparently I am wrong tho. I wasn't sure how to tell the difference between LED tail lights and non LED tail lights.
Old Oct 1, 2015 | 04:08 PM
i8acobra's Avatar
i8acobra
The new plug is a bulb base. Unscrew the black cap from your stock light. Follow the wires inside. Do they go to a bulb socket? Unplug the bulb and use that wire as an adapter.
Old Oct 1, 2015 | 04:15 PM
350z82's Avatar
350z82
Ok, checking on that now. will respond in a few minutes.
Old Oct 1, 2015 | 04:26 PM
350z82's Avatar
350z82
Removed the plug. It appears to go into a circuit board or something, not a bulb.
Old Oct 1, 2015 | 04:50 PM
350z82's Avatar
350z82
Well, according to my VIN, these should be LED tail lights. Ugh.
Old Oct 1, 2015 | 04:55 PM
i8acobra's Avatar
i8acobra
Yep. Thought maybe you had an oddball, but lights should be '03-'05 or '06+.
Old Oct 1, 2015 | 05:02 PM
350z82's Avatar
350z82
I'm just so confused. the OEMS are LEDS, but these are too, and yet they have different plugs. I've tried looking up other LED tail lights for 06 350z and from the ones were i can see the backs of them, they all have the same plug as the ones i've purchased. The hell, why is mine different!?!
Old Oct 1, 2015 | 05:11 PM
dcains's Avatar
dcains
Perhaps the ones you bought are an LED conversion for the earlier non-LED cars? As I said, I'd try and find out why your original,ones are leaking, and seal them up. No aftermarket light you'll find will ever look as nice.
Old Oct 1, 2015 | 05:16 PM
350z82's Avatar
350z82
At this point you might be right. Just frustrating, I like the aftermarket ones that are not all completely red.
Question, for those that do have the LED tail lights, are your plugs like my oem lights or the plugs on my oem lights just odd?
Old Oct 1, 2015 | 05:27 PM
dcains's Avatar
dcains
Never counted the pins, but the ones on my '08 look like the original ones on your car. There's nothing wrong with your car, return the other ones.
Old Oct 1, 2015 | 05:30 PM
350z82's Avatar
350z82
Doing that right away. Thanks so much for the help Dcains and I8acobra. This is why I love this site.
Old Oct 1, 2015 | 05:33 PM
dcains's Avatar
dcains
I'm still surprised your OEM lights are leaking. If they're not cracked, inspect the seams and try to seal them up.
Old Oct 1, 2015 | 05:38 PM
350z82's Avatar
350z82
If i can find the spot, once i drain all the water out (there is alot, been raining for about a week now here) should i use a hair dryer or something to get all the moisture out of it before sealing it?
Old Oct 1, 2015 | 05:41 PM
i8acobra's Avatar
i8acobra
This. Those are LED lights for the '03-'05. They convert the non-LED to LED. That's why the plug is a bulb base.
Old Oct 1, 2015 | 05:56 PM
350z82's Avatar
350z82
Ah, welp, lesson learned, do not order from Andysautosport.com.
Thanks again so much I8acobra and Dcains so much for your help. I already have the tail lights repackaged and ready to ship them back out tomorrow once I get the label from Andys. Thanks again, Mods can close this thread whenever as my issue has been resolved thanks to some awesome members.
Old Oct 1, 2015 | 06:25 PM
dcains's Avatar
dcains
Sounds like a good idea. Just don't use super glue, or any other cyanoacrylate glue, as it will fog the plastic.
Uriyo_
Sep 8, 2021 08:46 AM
samansharif
Sep 25, 2015 12:31 PM
