LED Turn Signals & LED Dome Lights!!!
Old Feb 28, 2004 | 04:48 PM
juhko's Avatar
juhko
ares, is it the taillight for the G35 coupe or sedan that runs
at $2K each? I would guess the sedan since it looks to have
more of those special LED...
Old Feb 28, 2004 | 07:55 PM
DIGItonium's Avatar
DIGItonium
Nah... the type of LEDs are some sort of oval shaped super flux type. They're just high brightness kinds that are put together in a cluster.
The Z housing was designed to diffuse lighting from incandescent bulbs, so the LED bulb we'd design need to be sufficient for this type of lighting.
The goal here is direct replacement of stock bulbs... it's easier to sell this way.
It's hard enough to clear the headlight housing... not many people (including myself), would want to invest in modifying the assemblies. It's too risky...
Old Feb 28, 2004 | 09:31 PM
ares's Avatar
ares
Veteran
that is the list price for G35 coupe "brake and stop bulbs" which is seperate from the price of the assembly according to the listings. Im not sure precisely what all is included in what. but something in the G35 tail light is 2grand; clearly that includes the LEDs, but I dont know what else. and Im unsure if thats a pair or each.
Old Feb 29, 2004 | 11:43 AM
DIGItonium's Avatar
DIGItonium
That's an insane price... esp since the car costs just a lil bit more than the Z.
Old Mar 4, 2004 | 04:50 PM
silversonic's Avatar
silversonic
I just got my 194 led and I'm very impressed with the brightness!
Tempting to buy the turn signal leds too but at 90 bucks it's a little too steep (I know the material is expensive)
So will you consider using only 1 led for each turn signal?
I'm sure more people will be interested if it's cheaper.
Old Mar 4, 2004 | 05:14 PM
ares's Avatar
ares
Veteran
I could do 1, 2, 3 or 4.
but of course brightness would be reduced. 1 would IMO be a bit inadequate for the function. I had 2 in mine for some time and it was ok, Id say 2 would be the least Id be comfortable using.
Old Mar 4, 2004 | 06:22 PM
jckolnturn's Avatar
jckolnturn
How difficult is installation on the park lights and the turn signals. What kind of time and tools will i need?
Old Mar 5, 2004 | 08:39 AM
silverstoneTT's Avatar
silverstoneTT
Installation is really easy. I dont have the link but there are directions on Ares' site. All you need is the jack to lift the car up, a screwdriver thing and a flat head screwdriver to pop the little plastic rivets out. Once you do one side doing the other should only take 2-4 minutes to get the bulbs out and the new ones in.
Old Mar 5, 2004 | 08:44 AM
ares's Avatar
ares
Veteran
silverstone has the right idea.
http://www.rasecreations.com/bulbreplacement.htm
theres the details. its possible to be done in about 10min. Id expect 20-30 if your not familiar with it.
if youve done sidemarkers install before, then its the same thing(minus anything to do with the bumper.)
Old Jun 10, 2004 | 07:27 AM
FairladyZ's Avatar
FairladyZ
Just found this doing a search. How do the front led's look in the day, also can you do other colors? How do they look with the head lights on?
Old Jun 10, 2004 | 08:36 AM
ares's Avatar
ares
Veteran
being in a seperate location from the headlight, its light does not interfere with it.
any color LEDs come in I can do, amber, red, white, blue, cyan, green.
during the day they are still clearly visible.
Old Jun 10, 2004 | 08:40 AM
ares's Avatar
ares
Veteran
led
Old Jun 10, 2004 | 08:41 AM
ares's Avatar
ares
Veteran
regular, half the color your even seeing, is its own amber reflection.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
