Where to buy QX1 (pikes peak white) paint
Old Aug 4, 2019 | 07:52 PM
savedbygrace's Avatar
savedbygrace
Default Where to buy QX1 (pikes peak white) paint
Hey everyone,
Wondering where I can buy the paint to DIY paint a few panels on the Z which is Pikes Peak White.
I have a compressor, a couple of paint guns, and can rent a bay from a pro that will help me do the painting, but I need the paint and ideally don't want the water based stuff...I want the real PPG paint that Nissan uses.
If I remember right, there's another company that also sells paint that is most likely PPG since the paint codes are the same in the two company's item numbers...but I can't remember who that other company is....I learned it a few months back in a forum and a pro was explaining that he's used both PPG and this other company and blah blah blah...they're the same or so close it's inconsequential.
I plan on painting the front and rear bumper covers, and my side skirts to freshen them up. Car is factory paint except for a rear which was painted really really well by someone in CA I believe. Don't know who did it...but it matches well.
All help appreciated as always, and yes I know having a pro do it will be best...but I want to learn and if I can't get it done myself then I might pay someone later, but I want to get a handle on painting and am confidant I can do it, and have had pros reassure me I can do it as well...I know the steps and have studied a lot, and helped paint a car years ago, but for now I'm stuck on buying the paint for the best price.
Thanks sincerely,
Saved
Old Aug 4, 2019 | 08:57 PM
mr. sparco's Avatar
mr. sparco
IIRC PPG Shopline is the solvent based paint, however, I believe they have been fazing out all the solvent based paint the last few years. I used to paint my own parts and own several paint guns as well but don't really care to smell that stuff anymore. I used to buy all my supplies from local suppliers, search "automotive body shop supply" and see what comes up near your area.
Old Aug 5, 2019 | 04:19 AM
jv350z's Avatar
jv350z
the "pro" should be able to point you in the right direction as far as where to source the stuff, no?
Old Aug 6, 2019 | 10:44 AM
Zoom750's Avatar
Zoom750
For the DIYers, I have heard that automotive touchup works well. Seems a bit pricey though, for the gallon.
https://www.automotivetouchup.com/
Old Aug 7, 2019 | 08:06 PM
savedbygrace
The pro is one person with a bank of data in his brain...other brains have different databases of different options...always good to get as much info as possible before buying has been my experience. So I ask the very helpful brains of this forum to steer me to things I or others wouldn't have thought of.
Old Aug 7, 2019 | 08:08 PM
savedbygrace
Appreciate the great reply, thanks sincerely. I remembered something was up regarding PPG...I think that was it...doing away with solvent based paint...prettttyy sure there's another company that took over the solvent line as I think out loud.
The main shop in my town that used to carry PPG has converted to water based only...I had called them a few months ago. I'll try some other shops though, and thanks again.
Old Aug 7, 2019 | 08:11 PM
savedbygrace
Thanks Zoom750...I should've fallen in love with bowling or dirt...anything that isn't so expensive all the time.... but bowling can't take you for a nighttime cruise through the canyons...so I guess I'm stuck with expensive.
Old Aug 7, 2019 | 09:07 PM
bealljk's Avatar
bealljk
I used this kit and it was an 8 out 10 color match to my pikes peak white qx1 (is pikes peak white the same as glacial white?) and I was overall pretty happy with it. I bought about 150% of what I thought I needed and I would suggest the same if you use aerosol. It was pretty easy to use and straight forward although I had a guy that has paint/bodywork experience. I sprayed in a vented spray booth with well prep'd surfaces.
https://www.ebay.com/itm/Touch-Up-Cu...kAAOSwvUlWtXqJ
I'll upload some pictures for reference.
Old Aug 7, 2019 | 10:51 PM
savedbygrace
Man you are my newest favorite forum member...THANK YOU...sincerely....
How many cans do you think I'd need to paint a front bumper cover? Any chance there'd be enough left over to do two side skirts?
Can't wait to see the pics...really want to get this front end project behind me but done beautifully.
Thanks again!
Old Aug 8, 2019 | 08:23 AM
bealljk's Avatar
bealljk
Thanks again!
you got it - we're all buds around here!
I emailed / contacted that seller and ordered 4 sets of base/pearl/clear and he had them available just not listed. I did a CF hatch (that completely **** the bed on me) and a front bumper with the 4 sets and I laid it on pretty hard and I had extra. I would think if you ordered 3 sets you'd be fine. You may be able to get away with 2 sets.
I also bought a few cans of the QX1 variant from the local autoparts store almost as a pre-base. So I had a 'close enough' white staring point rather than a raw black/dark starting point before I used the 3-coat stuff.
Old Aug 9, 2019 | 10:58 PM
bealljk's Avatar
bealljk
Hope this helps Saved ... note that I have the OEM clear bra on and it makes the paint mis-match that much more
Old Aug 10, 2019 | 09:22 PM
savedbygrace
Hey thanks again with two exclamation points this time ! !
I'm guessing a little of course, but without the clear bra on I think the paint kit would be a close enough match for my daily driver....can always have it professionally sprayed after I win a few car shows for most shades of white on one vehicle. Yours does look good though, and over here the Z looks nice too, I'm pretty confident I can get it looking pretty decent but certainly not as nice as a skilled and experienced professional.
Quick question...do you know of any vendor on eBay or anywhere else that would paint match to something like the fuel door if I mailed it to them? I'm no professional painter so I'm not aware of all the "can also do this" options available from paint shops or painters when it comes to customer requests.
Thanks bud, you've made me wiser. So now I am beer. (sorry...)
Saved
Old Aug 11, 2019 | 08:19 AM
bealljk's Avatar
bealljk
Saved
Thanks! For a $40 DIY it could be worse. You get right up on it and you can see a slight difference. I dont know if the rattle-can'd portions would match a little better if exposed to sun for a few months??
I dont know of any vendors that would color match like that but it doesnt hurt to shoot them a message and ask(let the thread know because I would do that next time. They may? They likely have the equipment to do so and if I remember right he only had one set of paint and he mixed the two additional sets I needed for me.
Old Aug 15, 2019 | 12:24 AM
savedbygrace
How was it a $40 DIY? I was loving you until the confusion....the paint kit you linked me to is $80 a set and you ordered three or four sets I think?
I need a DIY on a better brain.
Saved
Old Aug 15, 2019 | 04:38 AM
bealljk's Avatar
bealljk
Oppppppsssss .... yea, it’s was $80! Not $40
Old Aug 15, 2019 | 11:41 PM
savedbygrace
Don't brain like I brain man...life is so much harder on my brain.
Old Aug 16, 2019 | 06:02 AM
bealljk's Avatar
bealljk
All those fumes!
taker777
Nov 13, 2011 02:19 PM
sandthepilot
North West
13
Mar 6, 2009 12:43 PM
SFMACGUY
Oct 12, 2008 11:58 PM
d!abolic
Aug 26, 2008 07:59 PM
EM-EFER
Mar 22, 2006 08:38 AM
