Inside door panel window seal
Old May 2, 2020 | 08:12 AM
Nimbus350's Avatar
Nimbus350
Default Inside door panel window seal
Does anyone know the actual name of this part, the part number, or if it's even available to buy separately from the door panel? It's the trim piece on the upper part of the door panel that the window runs against.
Old May 17, 2020 | 06:11 PM
calvin.w's Avatar
calvin.w
Did you ever find out?
Old May 17, 2020 | 06:35 PM
Nimbus350's Avatar
Nimbus350
No, only thing I have come across is the piece that goes on the outside of the door. I asked Z1 and they thought it was part of the door panel not sold separately.
Old May 17, 2020 | 06:56 PM
calvin.w's Avatar
calvin.w
Try going to a dealership. They can print you out a diagram of the door with every part number on it. That's what I have to do sometimes.
Old May 18, 2020 | 06:14 AM
Freise's Avatar
Freise
I'm 90% sure it can be replaced, it has a single metal dowel at one end and bent metal tabs holding it in place. I doubt that it can be purchased separately. I have several door panels but I don't know if shipping something with it's length would be worth it... I'd suggest looking for a salvage Z in your area
jmasi
Aug 13, 2013 06:51 AM
n8vz
May 13, 2007 01:45 PM
yanotkaj
Jan 18, 2006 06:25 PM
JimH
Nov 13, 2004 09:40 AM
ZZtopp
Sep 30, 2004 10:41 AM
