Hi everyone
I am building a complete new body for my Zed
Thought I would share
Re Body New and different headlights Spliter and new nose foamed , working on the fenders the rear hatch will be replaced with a smaller trunk , no rear window the whole body will be fiberglass plug for the roof scoop the back , new lights , etc
Welcome- this looks like quite a bit of work and thanks for sharing. What kind of condition was the donor Z in when you started this project? Did you retain the OEM quarter panels?
Hi dkmura
Ok well there seems to be some interest here in my build
The doner car is a mint condition 2005 35th Anniversary Edition with low miles , I know it seems like a shame to pick a rare and mint car for a new look , but I wanted a good car under all that work .
So I think I will start from the very beginning
A friend and I were interested in the Vaydor built by Matt McEntegart based on the G35 , so we went to Tampa Florida to visit Matt and check the Vaydor out , we were very fortunate to get to go to a Hot Import Nights car show where Matts Purple convertible was the feature of the show .
The next day we went to Matt's shop and he gave us the tour , answered all our questions , super nice guy not to mention extremely talented.
The Vaydor is a very cool car but the logistics of the price and the difference on the dollar plus shipping to Canada were just not viable .
So on the flight home I thought to myself , hey I am a handy guy why don't I build my own car !!!!
And so I decided to go for it , I picked the Nissan 350 Z because I am already a Nissan guy and the Zed is great bang for the buck .
From the beginning , I had to set up a shop to do Fiberglass work in , my existing shop is attached to my house and you can't do glass there .
So here we go !!!
I built some For wooden wheel to simulate the new 22 inch Rims this works well for test fitting and the expensive ones don't get destroyed during the build the fronts are 3 1/4 inches wider and the rears are 5 1/4 inches wider this was an empty building when I acquired it Disassembly the rear hatch will be deleted and so will the rear window building the mold for the inside hatch replacement mold for replacement hatch laying up the inside hatch part the inside hatch replacement will have a smaller trunk .
next is the outer hatch replacement building the plug to replace the outer hatch panel tons of glass laying it up building a base for it to stand on once it gets flipped over to make the new part from the mold here is the mold , it's a one time part so no gelcoat this is it with the filleting wax removed the two parts sitting together ( inside sitting in the mold for the outside ) laying up the outside part curing outside part getting trimmed the two together on the car trunk hole cut out
Just to let you know I have been building this body for almost 2 years now it's getting close there are like 2000 pictures , hard for me to pick which ones to show you .
On to the the trunk parts the bottom of the truck gets built into the back lid ,until it needs to be cut out .I will make a copy of the bottom so I can build the top of the trunk lid on the bench instead of leaning over the back of the car this is the plug for the piece that goes over the rear suspension tower brace laying up the mold here is the mold ( again a one time part no gelcoat ) the mold trimmed the part layed up in the mold the part out of the mold the part trimmed and on the car the perimeter for the trunk opening this will eventually get trimmed off around the very outer edge and the trunk seal will sit on the standing seam these slats will become ridges in the base of the lid constantly checking plumb and level to stay on track .
I made up some flat fiberglass to cut pieces to fit in between the trunk edge and the roof here you can see I made patterns with bristle board , no cheating here with a $100,000 dollar scanner here's the pieces traced out on the flat glass prep for the closer plates taped into place then fiber glassed into place it turned out well I thought
I'm so wet.
Fiberglassing takes a lot of patience and artistic skill. The way your hatch came out compared to what others have tried making here are night and day. Very impressive.
Just wanted to show the lower or bottom half of the hatch replacement , this seals on the factory rubber just like the hatch did .
So here you can see it off the car , on the car and from inside the car .
The flange hanging down will be trimmed off once the upper and lower are bonded together .
More on the Scoop !!
This was a very difficult part to make and keep symmetrical
Ok this is ready to take a mold of ,the red part is called a plug (a finished part you want to copy ) the plug gets several coats of parting wax (high heat mold release wax ) then gets sprayed with PVA polyvinyl Alcohol another release agent next it gets black tooling Gelcoat it can take the heat from the part curing in the mold then it gets several layers of fiberglass I like to add plywood to help hold the structure and it gives it a base to rest it on to work So this is the position it will be in to layup the new part Because of the shape of the part I decided to make the mold in two parts so it wont break getting it out so I cut the back off and made it removable Ok its time to take the red plug out !! you have to be careful here not to scratch the mold with any tools So we use wooden wedges and Baam it's out Shitty part is the red plug is now garbage !!! Plugs usually bust because they aren't very strong Ok so next is prepping the mold to make a part it now gets several coats of wax and also gets sprayed with PVA ready for the white gelcoat the white gelcoat is applied , it needs to dry overnight usually next day two units of Fiberglass here it is layed up and still wet and curing next day its ready to get popped out of the mold I trimmed the edges first here just for safety , the flange will still need to get trimmed to go on the car Here it is out of the mold Here you can see pulling off the PVA the PVA is like liquid saran wrap , you can usually pull most of it off in large sections one of the nice things about PVA is it water soluble here it is ready to be trimmed and sitting on the car
Intrigued by the roof scoop- will it be functional, and if so, how? Vent the interior via a roof vent? Or just flow air to the rear window?
Hi the roof scoop is Not functional , it's purpose is to help with roof structure ,( and cool factor ) it could very easily be made functional to pass air through to the back or into the cabin .
Thanks again for your interest .
Cheers
Based on your progress and techniques, I would say this is quite the understatement. I've dabbled a little in fiberglass and carbon fiber, but nothing to this scale. Truly impressive.
I used to make copies of evo hood scoops to install on factory hoods. I would use bowling alley wax as a release agent. It worked perfectly. I had the mold for so long before i got rid of it from not really being in that type of scene anymore.
Is this what you do for work, or just a great hobby that you decided to take on?
Hey thanks for the support guys , I am actually a welder , fabricator , mechanic .
But I have worked in many different fields and picked up a few things along the way .
Lets take a look at the front of the car . These are the headlight buckets, made of wood and body worked. These are the plugs to make the part so next is make a copy of them and then make the part form them so this is the first layup of fiberglass Now it gets popped of the plug with little wooden wedges , not to damage the fiberglass here is a good shot of the PVA getting pulled off So now these get waxed and PVA so they can be layed up with fiberglass here they are glassed and here they are on the car after being trimmed up This one needed some clearance for the windshield washer bottle
These headlight buckets will get glassed into the the whole front under the bumper piece , that the nose and front fenders and hood all come together .
Next is the front lower bumper , spliter and fender support
So this piece ties the front of the car together , The spliter will bolt to this and the fenders at the bottom and inside under the hood there are provisions to run air ducts to the brakes and cold air intakes , not to mention a large are to cut out for the radiator
tons of hours have gone into this project
I don't know who invented sanding ..........
after all these parts are fiber glassed together the plug goes in the garbage ...........totally disheartening
I have extended the front bumper 2 inches giving more room for inter coolers and oil coolers , still retaining the factory tow fixture
so here you see the white part with the purple this is ready to be glassed , this ties the headlight pots and the front fender fastening area together
this whole nose should have been glassed at this time but I got too excited and wanted to see some foam and shape happening , it's ok I just have to do it after the nose gets glassed and pulled off .
