Center console dash looks bad
Old Oct 11, 2020 | 06:54 AM
JUSTINC2001's Avatar
JUSTINC2001
Default Center console dash looks bad
so idk if the old owner tried to wrap the dash or what he used on this or is this original from factory just peeling but what can I do to make it look better
JUSTINC2001
Old Oct 11, 2020 | 07:32 AM
travlee's Avatar
travlee
Master
Looks like he painted over it, see the ping pong paddle looking stuff tonthe left of the radio, that is the original texture
Old Oct 11, 2020 | 08:00 AM
dkmura's Avatar
dkmura
General & DIY Moderator
You'll need to remove it, carefully disconnect the gauges and strip/sand the surface. Once you get the surface completely smooth, prime and use apply interior flat black. That looks pretty rough, so your other alternative is to purchase a replacement waterfall panel off fleabay.
Old Oct 11, 2020 | 08:15 AM
Heel Til I Die's Avatar
Heel Til I Die
It looks like the previous owner painted it. Very poorly, at that. Either too thick on the initial coats or s/he didn't let the paint cure properly and there is poor adhesion. Strip it down, sand it, use and adhesion promoter, and following the proper spray instructions. Prep is 90% of getting good results when it comes to paint.
While you're at it, get a decent dash kit like the Metra 99-7402. By the looks of it, your head unit is crudely stuffed in the OEM receiver opening and just sitting there. There's no point in refinishing the waterfall if your received is going to look like some hack job.
Old Oct 11, 2020 | 08:41 AM
travlee's Avatar
travlee
Master
Prob didn't have factory ears
Old Oct 11, 2020 | 08:44 AM
JUSTINC2001
Since you speak of the radio I actually just bought the oem radio brackets off eBay bc it didn’t have them when I bought the car and thank y’all for the suggestions
Old Oct 11, 2020 | 09:29 AM
DarkZ03's Avatar
DarkZ03
Paint, vinyl or hydrodip. Or if you want to spend more they still sell the carbon fiber kits for those.
Old Oct 11, 2020 | 11:02 AM
JUSTINC2001
What grit sandpaper do you think I should work with
Old Oct 11, 2020 | 01:58 PM
dkmura's Avatar
dkmura
Start with 200 grit and work up from there. Get a sanding kit with a variety of sandpaper to allow you to work the surface.
Adriano
Sep 18, 2018 06:33 AM
Shermanator
Feb 5, 2011 05:11 PM
350junkie
Feb 6, 2009 10:31 AM
doodeitstom
Jan 17, 2005 03:31 PM
