Loose window
Old Oct 17, 2020 | 07:44 AM
NzZ's Avatar
NzZ
Default Loose window
My drivers side needs a new window regulator. It’s an 03 350z and years ago I had the dealer so the TSB for the grease streak. Ever since then the drivers side window has seemed a little loose. By that I mean when the door is opened the motor actuates the drop but the window doesn’t go down the correct amount. It’s loose enough that with light pressure it moves to the correct location. The window also rattles a bit if it’s down and the door is closed. Any advice on how to fix it? I’m not sure if it’s loose bolts for the window or if the felt piece installed at the time of the TSB is worn.
Thanks for the advice,
NzZ
Old Oct 17, 2020 | 10:35 AM
travlee's Avatar
travlee
Master
NzZ
Take off door panel and look
/thread
allycat
Nov 16, 2009 05:43 AM
Austin350ZRed
Mar 30, 2006 04:22 AM
mixedup
Sep 15, 2004 05:39 AM
