Seats with convertible
Old May 7, 2021 | 07:58 AM
05350zvert's Avatar
05350zvert
Default Seats with convertible
Has anyone replaced both seats in a 350z and been able to keep the convertible top operational? The seat switch would keep it from opening i believe. Also my top will not go back the storage compartment door will not open, and the top wont lift in the back to open the storage, is it likely the 5th bow?
Old May 7, 2021 | 08:11 AM
Heel Til I Die's Avatar
Heel Til I Die
https://my350z.com/forum/350z-roadst...table-top.html
https://my350z.com/forum/350z-roadst...-roadster.html
Old May 7, 2021 | 08:29 AM
05350zvert's Avatar
05350zvert
Thanks.
Old May 7, 2021 | 09:42 AM
Heel Til I Die
Sure thing - as far as your other question - it sounds like your top is not operating at all. There's no telling what that could be. There are many sensors and conditions that must be met in order for it to function correctly. I would recommend downloading the FSM and going through all the troubleshooting steps. I've attached a copy. I had to split it into 2 different parts based on the file size.
File Type: pdf
File Type: pdf
Old May 7, 2021 | 09:49 AM
05350zvert's Avatar
05350zvert
I've been reading the fsm, the widows come down, the seat tilts, and the storage deck doesn't open, so i'm going to have to probably pull the inside out to manually open it. it makes it to op2 where it unlocks then nothing happens.
arcada
350Z Roadster
Nov 14, 2012 08:29 PM
MaelstrØm
Aug 29, 2011 07:35 AM
ronnie
Nov 8, 2003 04:01 AM
Blue350z
Jul 8, 2003 01:20 AM
nick800
Apr 25, 2003 06:14 AM
