Climate control module ribbon.
Old Aug 18, 2024 | 07:33 AM
CSCensored's Avatar
CSCensored
Default Climate control module ribbon.
When I first bought my car I noticed the ac module control ribbon was cut I didn’t care because it was summer, but now it’s coming into winter I would like me heat. How can I but just the plugin and not the $150 ac control module when I just need the ribbon.
Old Aug 19, 2024 | 05:17 AM
Heel Til I Die's Avatar
Heel Til I Die
According to this thread, you can open the white box, trim the cable, and then insert the ribbon into the connector.
https://my350z.com/forum/maintenance...lat-cable.html
Old Aug 19, 2024 | 08:08 AM
dkmura's Avatar
dkmura
General & DIY Moderator
I think the OP is missing the connector for the HVAC ribbon. He'll probably need to purchase that, but I'd suggest going to a local salvage yard to get one.
Old Aug 20, 2024 | 12:55 AM
icer5160's Avatar
icer5160
Yep. Salvage yard is your best option. I would also check altimas and maximas from the same year period. The AC amp/meter is common on many Nissan models. Even if the pin out is different, I would wager the harness plug is the same.
Good Luck!
-Icer
Killabee350z
Mar 29, 2017 08:54 AM
The Burgh
Nov 8, 2013 03:30 PM
luticrist
Feb 11, 2010 09:01 PM
IronYuppie
Jul 16, 2008 02:44 AM
