auto shift knob
Can anyone recommend an automatic shift **** for an 03 model. I received one from performancenissan.com and it would not fit even though they pulled it up on the computer and it said 03 and 04 models. Any help would be appreciated.
Originally posted by whosdady
Are you talking about any shift **** or just replacing the 03 **** with an 04 ****? I replaced my 03 with an 04. There is one minor DIY mod you need to do first...
That pic is of the 04 ****.
The 04 **** fits the 03 stick. You first need to remove the 03 ****, then place the 04 **** on the stick. You will notice the grooves where the pin catches is lower on the 03 compared to the 04. Therefore you must make new grooves.
I put the 04 **** on, took an exacto knife and made a mark on each side where the new groves need to be made. Than I took the **** off and used a thin saw blade to make new grooves. It works great. However, I am buying a lot more mods and will be probably selling this ****. PM me if you are interested.
Originally posted by pkc415
What is that DIY mod?
Pull the silver tab at the bottom of the **** just below the leather down. (It snaps) Then pull the pin out (from teh front twards the radio) and pull the leather **** up. It comes off with a little tug. Takes all of 5 minutes.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
