aluminum pedals on base
Old Apr 14, 2004 | 05:21 PM
tommym's Avatar
tommym
Question aluminum pedals on base
Hey Guys,
I have a base, and I am trying to install the aluminum pedals on it. Has anyone done this that could help me out? I can't figure out how to remove the accelerator pedal.
Thanks
Old Apr 14, 2004 | 05:26 PM
yobri's Avatar
yobri
It's a clip on the back that needs to come off. After that the pedal flips down and you slide it off from there. The clip that I am speaking of is attached to the metal bar coming down to the pedal (pretty close to the top of the pedal).
Old Apr 14, 2004 | 05:32 PM
tommym's Avatar
tommym
How do you get the clip off? does it just pop off?
Old Apr 14, 2004 | 05:35 PM
yobri's Avatar
yobri
I wedged a [thin] screwdriver to pop it off, just be careful not to scratch the metal though. After that, the accel. pedal is a piece of cake. Second easiest pedal next to the dead pedal. The brake and clutch were the worst. Caused me to sweat.
Old Apr 14, 2004 | 06:01 PM
zand02max's Avatar
zand02max
Check the search if its working. There is a step by step guide with pics
Old Apr 14, 2004 | 06:06 PM
yobri's Avatar
yobri
That would be Jun's aluminum pedal installation. Search is down. Easiest thing to do would be to find the member Jun from the forum member list and then search all of his posts STARTING FROM the beginning, not recent.
Old Apr 14, 2004 | 06:16 PM
NismoKid's Avatar
NismoKid
https://my350z.com/forum/showthread....threadid=43586
No pictures
Old Apr 14, 2004 | 06:24 PM
yobri's Avatar
yobri
No pictures
He must have cleared his server space... it was a really nice pictorial that pretty much summed up the installation. Guess people will have to use their imaginations
Old Apr 15, 2004 | 08:47 AM
mrZeee's Avatar
mrZeee
jun huooked me up with some pics he had on hand (THANKS AGAIN jun!)...but the text is good and those brake and clutch pedals what a b*tch...soak the pedals in hot water...also lube a bit with some WD40 and use a small screwdriver to help "pry them on...
Old Apr 16, 2004 | 06:38 PM
tommym's Avatar
tommym
FINALLY! Yeah, the brake and clutch were the hardest part of it...once I figured out how to get the accelerator pedal off. My fingers were a little sore after this, but it was worth it. Thanks for the help.
Old Apr 17, 2004 | 07:02 AM
Jun's Avatar
Jun
Sorry for the delay! Did you get the accel on? I took some pics for you so that I can explain it better, i have to e-mail them to you because the pics are HUGE, let me know if you still need them.
About the installation guide, the server where the pics were posted took a dump, it's a friend's server, and i lost all the pics , but i'm going to try to make another guide with what i have now.
Old Apr 17, 2004 | 02:23 PM
tommym's Avatar
tommym
Yeah, I have the new pedals on. Thanks for the pics Jun...I got the pedals installed before I got the images, but I am glad I was able to look at the pics and know that I did it right. Thanks for all of the help guys.
EnjukuRacing
Sep 30, 2015 06:55 AM
