Veilside v1 lip problem - help?
Old May 1, 2004 | 05:59 AM
Yancy's Avatar
Yancy
Default Veilside v1 lip problem - help?
I have the fiberglass v1 on a chrome silver. Before it got painted I test fit it to see how it looked. When taking it off, I must not have been careful enough and cracked the driver side of it where it wraps around the lower part of the bumper. The crack is verticle and about 1/4 or so of an inch. I showed the body shop that did the paint work, the siad they could fix it before paint, and I paid them to repair it before painting. It all looked good when I picked up the pieces yesterday. They repaired it from the inside, which I think was not good because it even made the fit tighter than it already was. Anyway, it went on well and looked great, until the crack just popped back into being. I think the pull on the lip (extra stess) must have pulled the repair apart.
I hope there is a way a shop can fix this while the lip is on the car. I'm thinking that they could bondo it or whatever on the outside, then sand and repaint the area of the lip while its on my car. Does anyone know if this can be done? Thanks.
Old May 1, 2004 | 07:03 AM
Blue Batmobile's Avatar
Blue Batmobile
Inventor
Blue Batmobile
That's why I got the urethane version.
Bat™
Old May 1, 2004 | 11:32 AM
Yancy's Avatar
Yancy
I'm glad you have the urethane version BAT, but that does not mean **** to me. Maybe you missed the question, does anyone know if there is something a body/paint shop can do to fix it?
Old May 1, 2004 | 12:20 PM
Scorch268's Avatar
Scorch268
if they can bondo it, sand it down, prime, paint,should be no problem, relax
Old May 1, 2004 | 01:09 PM
z327's Avatar
z327
They can repair it. But make sure they use a two part marine epoxy that is for boat repairs. Bondo will crack.
The crack should be ground out and cleaned thoroughly. Mix up the two part epoxy (fiberglass repair) and apply to the crack like you would bondo. I have used Marine Tex in the past with good results. It can then be sanded, primered and painted while its on the car. Its better to do the repair on the car while the part is already in a stressed condition. If you repair it off the car and put it back on it will crack there again or in a near by spot.
IMHO
Old May 1, 2004 | 03:44 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
it can be fixed but it is $ to fix fiberglass....
jeff had his fiberglass bumper fixed and re-enforced.. it almost costed as much as a new one!
Old May 1, 2004 | 05:30 PM
Yancy's Avatar
Yancy
Thanks for your response Z327. It makes me feel a lot better to know that it can be done. I was planning on having them repair it while it was on the car for the same reaon you mentioned.
Jason, I know what you mean on cost to repair fiberglass. However, I don't plan on being charged for this repair because I literally just paid them yesterday for the repair to the front lip, and to paint the rest of the V1 kit with the data system rear spoiler. The lip went on fine and held without cracking for like 10 minutes. The way I see it, their 1st attempt to repair the crack did not work real well.
Old May 1, 2004 | 08:06 PM
Jason@Performance
Performance Nissan
Did they install it or you?
good luck with it what ever happens...
Old May 2, 2004 | 05:48 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
Jason did you ever find the pricing/part no for the urethane V1 ?
Dymsi
Sep 29, 2015 11:32 AM
350Zteve
Apr 10, 2004 10:20 AM
aalzuhair
Mar 4, 2004 03:38 PM
zeroday
Feb 12, 2004 04:42 PM
1200tt
Jul 16, 2003 07:45 AM
