Vortech filter change
Old Dec 13, 2004 | 03:59 PM
aron's Avatar
aron
Default Vortech filter change
I have had my vortech for about 10k miles and still have not changed the filter. Am I way past due - when should this be done? And is their a direct replacement from vortech im assuming?
Old Dec 13, 2004 | 04:23 PM
booger's Avatar
booger
If you have the original filter , it is a K&N filter and can be cleaned with there cleaning kit and put back in . Easiest way for me to remove it was to take off the innner fender well . Loosen the clamp and pry it off the blower and push it down . The filter bends pretty easy...Bill
Old Dec 13, 2004 | 06:57 PM
SungNamZ's Avatar
SungNamZ
As you have seen, and as booger describes, removing/cleaning/changing the filter is not simple. CaneZMD has replaced the filter that came with the Vortech with: K&N #RU-4410. He indicates he can "clean it at every oil change". You might want to send a PM and confirm. Would be something interesting to post. He originally made this comment in a post on 06-13-2004 .
Old Dec 14, 2004 | 06:29 PM
aron's Avatar
aron
Thanks SungNamZ - I wasnt about to attempt it - think I may just get the new filter and have my shop take care of it. I'll look into it.
Aaron
Old Dec 14, 2004 | 06:37 PM
booger's Avatar
booger
I have that K&N # 4410.....I just thought it was to small to flow enough air ..even when clean....so its sitting on the shelf . If you want...for $30 I'll send it to you . Look to see what it cost ...I cant remember . Im guessing I paid about $40...Pm me
Old Dec 14, 2004 | 06:51 PM
aron's Avatar
aron
Is this the exact replacement filter for the Vortech unit.....or is it one that just happens to fit?
Aaron
Old Dec 14, 2004 | 07:07 PM
booger's Avatar
booger
Its smaller than the one that comes from Vortech , but will be easy to remove and clean
Old Dec 14, 2004 | 07:39 PM
aron's Avatar
aron
To get the exact replacement, Im assuming it has to come from Vortech? or does Vortech outsource someone else for the filter?
Old Dec 15, 2004 | 04:33 AM
booger's Avatar
booger
The original is good for just about ever....think 100,000 miles . But I think they are made for Vortech.....you would have to call Vortech on that one
lapham3
Oct 7, 2022 03:15 PM
