350EVO 3.917 Final Drive Gear with FI?
Old Dec 22, 2004 | 08:24 PM
dansouliere's Avatar
dansouliere
Default 350EVO 3.917 Final Drive Gear with FI?
I don't have any experience with the 350Z yet but I do have lots with mustangs.
It was a fact that the stock 3.27 gears were sluggish and 4.10 were the best mod for the money. But if you decided to install a supercharger the 4.10 were too much gear and the best choice was 3.73's.
I assume these same types of rules apply to the Z.
Can anybody comment?
Thanks
Old Dec 22, 2004 | 10:05 PM
spazpilot's Avatar
spazpilot
I would not put 350evo 3.917 final drive gears on a FI car. Too much of a traction nightmare. I am thinking about swapping my final gear for an the auto 3.28 gears
Old Dec 22, 2004 | 10:17 PM
phunk's Avatar
phunk
CJ Motorsports
i feel the same as spazpilot... at 425+ rhwp traction becomes a problem even on pretty large street tires... i also wouldnt want to have to shift any more often than i already do... i have also been considering the 3.28.
Old Dec 22, 2004 | 10:23 PM
dansouliere
Very interesting and just as I suspected.
Thanks for your feedback
Old Dec 23, 2004 | 06:16 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Yup, given the really short stock Z gearing, I would be looking a lower final drive.
Old Dec 23, 2004 | 07:02 AM
350G's Avatar
350G
GQ, you're the GB king . . . why don't you hunt us down a manufacturer / source
G
Old Dec 23, 2004 | 07:36 AM
ZippyCar's Avatar
ZippyCar
I have the 3.9 and the NISMO LSD... however since it is -15 out... I really can't give a good opinion on what it is like to drive / race with this set up and a TT under the hood. I am curious however.... I may have to get a new final drive....
Maybe someone could ask BJ at 350evo?
Old Dec 23, 2004 | 11:23 AM
ktown z's Avatar
ktown z
Would it benefit a centrifical supercharger since it builds boost on rpm. It is linear and not a surge like the twins. If anyone with the 3.9 final drive with a super snail has anything to say speak up!
Old Dec 23, 2004 | 12:10 PM
LOU's Avatar
LOU
I have a Vortech SC and I swapped my MT rear-end for AT gears. With longer gears you are able to stay in boost longer, shift less and the most noticeable change is the length of first gear.
With shorter gears you may reach boost faster, but you also have to shift faster and more often. The stock gears were better for drag racing, but for all around feel, the longer gears are better. Plus, I will be doing more road courses than drags with my car. And by adding longer gears top speed is increased once you get rid of the limiter.
The dyno showed that I did lose some torque with the longer gears. With that said the car still feels amazing . I couldn't imagine what shorter gears like the 3.9 would feel like. 1st and 2nd gear would probably be non-existent.
It really depends what you are looking for and plan to do with your car.
Old Dec 23, 2004 | 12:56 PM
bascelik's Avatar
bascelik
LouZer, you put AT's 3.35 final drive in 6MT car? Did it fit fine? I've been thinking about doing this as well, once I'm closer to 400whp...
Old Dec 23, 2004 | 12:59 PM
ZippyCar's Avatar
ZippyCar
Where do you get the longer gears? Just call up Nissan Parts? Sounds interesting as I track my car too.
Old Dec 23, 2004 | 01:01 PM
zero2prove's Avatar
zero2prove
That's my plan as well for our Z.
Old Dec 23, 2004 | 01:10 PM
LOU's Avatar
LOU
I was at the track and talking to a guy with a 5AT. He used to race cars and mentioned that he always switched out the automatic rear-ends for the manual gears. I mentioned that I wanted to do the swap and he said okay. It was just a simple pumpkin swap. Everything bolts up as it should.
So it was by luck, but ask around to see if anyone in your area will do the swap. I am happy with the swap and so is the other guy. I would not recommend it unless you are pushing some HP. Otherwise it would just make your car feel slow. I am at 415whp and the car feels great.
Old Dec 23, 2004 | 02:04 PM
Sharif@Forged
Forged Performance
The swap to an AT pumpkin is work while and very easy. Problem is..>i have searched all the junkyards and havent found one.
Also, with the lower final drive, Your 1/4 times should drop, since you wont have to shift into 5th gear at the end of the track.
Old Dec 23, 2004 | 02:09 PM
booger's Avatar
booger
I dont know if you would have any use for it , but I have an open read end out of my AT5 . Some shims and a bearing was taken out to get the MT6 3.5 LSD to work in mine . Id let it go cheap , but shipping might be a little high...dont know
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
