ARGGH! Still waiting on bearings!
Old Feb 4, 2005 | 07:24 AM
zimbo's Avatar
zimbo
Default ARGGH! Still waiting on bearings!
Man, I've been waiting on bearings for my rebuild for what seems like a lifetime! Anyone else have this problem?
The only good thing about it is that I'm using a second engine for the rebuild so at least I'm able to use my car. The waiting game is killing me though. The block is all ready to go--just those damn bearings.
--Steve
Old Feb 4, 2005 | 08:10 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I ordered mine last weeek from Courtesy Nisan. Everything should be at Courtesy Nissan today, and in my hands on Tues.
I know what you mean though....I am waiting for bearings and the torque plate.
Have they already bored and honed your cylinders? How about some pics Zim!
Are you going to Z-days? There should be some super fast cars there, and CP Racing is bring their mobile dyno for us to use!
Old Feb 4, 2005 | 08:37 AM
zimbo's Avatar
zimbo
gq... So you're saying that some dealers have bearings in stock?! My builder has talked to the local Nissan dealer and also SGP Racing, I believe. It's been about 3 months of waiting, so my assumption has been that nobody in the USA has them. Am I wrong?!
Should I have them go another route to get bearings?!
--Steve
Old Feb 4, 2005 | 09:13 AM
Enron Exec's Avatar
Enron Exec
I had to wait a pretty long time for my bearings too. Try Baker Jackson Nissan South in Houston TX.
Old Feb 4, 2005 | 09:15 AM
ZRAYGO's Avatar
ZRAYGO
again, AEBS resleeved my engine and i had to wait in total about 7 months to get my engine back...good luck...
Old Feb 4, 2005 | 09:32 AM
Sharif@Forged
Forged Performance
Zimbo, the dealers dont have them in stock, but they should be availible at the various Nissan parts Distribution Centers. I will let you know by Monday if there are any delays, but I spoke to Courtesy Nissan today, and he said they should arrive today at their dealership.
Old Feb 4, 2005 | 09:50 AM
natve4ply's Avatar
natve4ply
try performance nissan. i was waiting for a super long time for mine as well. also i needed to get thrust washers, which would take just as long too, but performance helped get them to me faster than expected
Old Feb 4, 2005 | 10:23 AM
going deep's Avatar
going deep
I actually walked into my local dealership parts center and ordered them. A week later I had 4 main bearings, 12 rode bearings and two thrust washers. All of these parts come from 3 warehouses throughout the country. The only possible reason it would take you longer to get a particler bearing is if it has to come from Japan. But rod bearings only come in 3 sizes and theirs only one size for the thrust bearings. Unlike the main bearings that have around 12-15 different sizes.
I actually have an extra set of rod bearings that I will sell for the price I paid if Todd doesn't need them.
I also have an extra grade 2 main bearing too.
I have eight of grade 1 and four of grade 2 rod bearings. PM if you want dibbs, I should know by early next week if I will need them or not. This extra set came from Courtesy Nissan and were a back up plan in case the local dealership plan fell through.
Ernie
Old Feb 4, 2005 | 10:32 AM
Sharif@Forged
Forged Performance
I love the new sign. I think I recogonize some of those parts! LOL
Old Feb 4, 2005 | 10:43 AM
zimbo's Avatar
zimbo
I'm going to do some leg work on this. I've asked my builder to send me the numbers from the block and crank. Once I know those I'll be doing some serious hunting.
Forgive the dumb question but what's grade 1 versus grade 2?
--Steve
Old Feb 4, 2005 | 11:29 AM
going deep's Avatar
going deep
--Steve
Rod bearing come in three different grades/sizes 0,1,2. The rod bearing sizes you need for you particler crankshaft is stamped on the pulley side with six numbers. For example, mine said 1,1,1,2,1,2,. Then double the number of rod bearings because they are sold by halves and now you have your rod bearings. However, if you are getting you crank polished or something, you run a small risk that you might end up needing a bigger size bearing. Your machine shop and/or performance shop will fit the bearings and measure them to make sure they are the right size.
The main bearings are a little more difficult to figure out. There is a five letter code on the crank and there is a five letter code on the block. Since you only have four main bearings....assume your crank as the letters A,B, C, D, E and you block has the letters F, G, H, I, J. Now, you skip the first letter in the crank shaft code and the last letter in the block code and match them. In my example that would be...B-F, C-G, D-H, E-I.
Now, we're almost done. Now, every dealership has a copy of a spreadsheet you need to line up the codes. Along the left hand side are the letters for the crank and across the top are the letters for the block. So, in my example I would go down the left side until I came to B and then go across until it lined up to F. Where these two cross is your main bearing grade. Like I said before, there are around 12-15 sizes, I can't remember the exact number. I have the spreadsheet at home and I will try and take a pic then post it. Or, you can stop by your local dealer and they can print it out for you. Once again, if you are polishing your crank the size might be off by a little and you might need the next size grade. This was a risk I took since I bought a new crankshaft and it wouldn't be polished.
Old Feb 4, 2005 | 11:30 AM
going deep's Avatar
going deep
Thanks! What happened to your new sig you had for a while?
Old Feb 4, 2005 | 03:45 PM
phunk's Avatar
phunk
CJ Motorsports
Good post here... very helpful for those who need to know about sizing their bearings.
-Charles
Old Feb 4, 2005 | 03:46 PM
g356gear's Avatar
g356gear
You have learned your lessons well young Jedi
Old Feb 4, 2005 | 05:42 PM
going deep's Avatar
going deep
You have taught me well, master
Old Feb 4, 2005 | 06:04 PM
Philthy's Avatar
Philthy
Boost Junkie
wow, I learned something new today... I wasn't aware that you needed to double the number of rod bearing by 2x... I hope my dealer is sharper than I...
Also, what's the part # for the thrust bearings, where are they located and what do they do...
Thanks.
Old Feb 4, 2005 | 06:47 PM
going deep's Avatar
going deep
Thanks.
The thrust washer part number is:12280-31U10
I can't seem to find them in the diagram below, but the...
#25 in the diagram shows the rod bearings
#26 in the diagram shows the main bearings
I am going to take a pic of the main bearing spread sheet, I hope it comes out good enough to post.
Old Feb 4, 2005 | 07:06 PM
going deep's Avatar
going deep
SORRY, but these pics are pretty blurry because I really had to zoom in with my digital camera. But, these should help along with my previous explanation. Or maybe they'll help you go blind,lol.
Old Feb 4, 2005 | 07:57 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
ernie... you are on a picture-posting roll!
our cars will be done soon, i can't wait to pass up a porche 911 TT (do they have those here in new mexico?)
Old Feb 4, 2005 | 11:08 PM
going deep's Avatar
going deep
LMAO.
That last pic makes me think that I've had a few too many beers tonight.
