*PICS* 350zDCalb & going deep -engine updates-*PICS*
Old Mar 28, 2005 | 02:25 PM
  #101
cloudy's Avatar
cloudy
350zdcalb, what would be your suggestion for me, knowing that i cannot afford new internals for a bit. Would you just tell me to wait tll i can afford both? which would mean i wouldnt have a FI car for AWHILE... or just buy the APS TT kit when i can, and start praying it wont blow, and start savn for forged internals?
Old Mar 28, 2005 | 07:02 PM
  #102
G35cTT's Avatar
G35cTT
If you can't wait run real low boost w/ alot of time retarding still risky but it would work. Phunk has FCon running no internal upgrades. If you want to go really cheap route just change the rods, that's what busted on my ride. I wonder how many APS kits there are that blew? Is there any? I just know there's not as many APS compared to GReddy.
Old Mar 28, 2005 | 07:23 PM
  #103
going deep's Avatar
going deep
Originally Posted by Speed Dreams
Think about this. 75% of people going forced induction DO NOT go inside the motor.
That's bull s**t for anyone to state your driving a time bomb by super charging or turbo'n your non forged motor.
All manufacterers know the limitations of the vehicles they provide FI kits for, and with further cautious diagnotics by the installer, post install ie, dyno/scan for a/f, boost and hp limitations. The end result is a 125 - 150 whp gain, safely. You push the envelope and you will blow it up, but the people that due should expect this or their just stupid because the info is there.
My advice to you on a light wallet....Upgrade suspension and get used to the car at it's limit. Install a dual exhaust with cold air intake and tire up grade. FI, big brakes after experience.
I won't ramble on here, email if you want to talk about built ups and racing, ................tripp
Authorized installer for : ATI , Vortech, Greddy.
What time bomb are you talking about?? Who mentioned that??
If you are referring to my post where I said, 375 and ticking, I was talking about my breakin period. I just built up my motor and ticking down to the end of my breakin period, lol.
Old Mar 28, 2005 | 09:47 PM
  #104
Speed Dreams's Avatar
Speed Dreams
Originally Posted by 350zDCalb
in the case of the 350z...as u have seen here on the forums..at least half a dozen people blew motors on 5.6lbs of boost...another dozen have blown motors on less than 8lbs..the vq35 is one motor where extra safety precautions must be taken to prevent this,,,,as u know, i learned the hard way...had i known the great potential for the catastrophic engine failure, i would have done a complete rebuild at the time of the turbo install...i wasted my time and money having the tt kity installed, only running well for less than 2 months, then blowing up...and it blew while driving conservatively...
...so IMO, it is not "bulls**t", i know from very personal experience, and another large handful of people here would most likely agree...
my advice, don't go forced induction on THIS particular setup unless rebuilding the internals, and most importantly, lowering the compression ratio!
Todd, I don't read these forums much and I wouldn't have read yours if some one had not e-mailed me an FYI(it's like " Gone with the wind"). I'm not going to get into the red tape of your situation nor play a key stroke banter game with you, you know why you blew your motor.....bad tuning and too much boost.
Should I air the facts so everyone knows?......
Old Mar 28, 2005 | 09:52 PM
  #105
Speed Dreams
Originally Posted by newmexicoZ33
Quick question for SpeedDreams,
I know this may be too soon, but I was wondering if you could give me a ballpark figure for the Turbonetics Single Turbo Kit install (with tuning time also).
As far as the FI on the stock VQ, I think the biggest factor in blown up engines is the tuning (or lack thereof). I honestly believe that mid 300 hp levels with the proper timing retard and a solid, SAFE A/F ratio are quite fine for the VQ35.
.........You nailed it Z33. I'm ordering two kits within the next two weeks, jump in and save a few bucks.
Call me and we will dicuss your car............
Tripp
Old Mar 28, 2005 | 09:59 PM
  #106
Speed Dreams
Relax man, had nothing to do with your reply....
Old Mar 28, 2005 | 10:09 PM
  #107
350zDCalb's Avatar
350zDCalb
builtZmotors
h
Old Mar 28, 2005 | 10:13 PM
  #108
350zDCalb's Avatar
350zDCalb
builtZmotors
i suggest that you do read some of the threads on this forum, very informative...you would learn much more about the vq35 motor and be able to make much more intelligent comments
"air the facts"
...is that some sort of threat...what do you mean.?..
you guys installed my kit...(BTW- you guys had it tuned to 7.5 lbs, when you told me it was 6lbs-because you based the psi reading off of the profec e-01, when it was later checked when i tuned my car, i was informed it had been at 7.5 lbs--> also explains why i was the ONLY one making 416 rwhp on 6lbs of boost in the world--because, i actually was not, just the "tune" you guys did was never checked against a mechanical boost guage)
so... i had the car tuned to another 1.5 lbs of boost, installed a timing harness to pull timing..and that's it....what is there to air???
the motor could not handle the forced induction, like so many others...like so many others that had great tunes...again, some get lucky...their internals hold up...others do not
no hard feelings
... the reason i CHOSE to take my car elsewhere is because of your guys' attitudes...like i was doing you guys a favor to give you business! i don't get it..think of me telling you this as a marketing tip..a no-charge consultation on better business management... just don't make that mistake with your next customer...
oh..and make sure next time you install a twin turbo kit on a 350z and you relocate the air bag sensor..make sure it is mounted vertically (so it will actually function properly)...mine, unfortunately was not given that consideration... that's scary!
good night buddy
Old Mar 28, 2005 | 10:18 PM
  #109
350zDCalb's Avatar
350zDCalb
builtZmotors
h
Old Mar 29, 2005 | 11:03 AM
  #110
Speed Dreams
.......There is two sides to every story, sorry you we not happy. Most people leave here content and satisfied. You just can't please everyone.
Old Mar 30, 2005 | 12:21 AM
  #111
LittleMT's Avatar
LittleMT
fascinating......
SpeedDreams, do you cats carry VP's Import race fuel?
Old Mar 30, 2005 | 07:42 AM
  #112
350zDCalb's Avatar
350zDCalb
builtZmotors
Originally Posted by LittleMT
fascinating......
aww..little mt... your back!
when does the track re-open?
Old Mar 30, 2005 | 10:52 AM
  #113
LittleMT's Avatar
LittleMT
awwwww...ltttle todddy...... you never left....
the track is for racers.....
Old Mar 30, 2005 | 11:11 AM
  #114
SungNamZ's Avatar
SungNamZ
fascinating......
Just got off the phone with Tripp at Speed Dreams. He does not have any "race fuel" on-hand. Apparently it became an issue with fire department. I understand there is a station on the east side of Albuquerque that has it in a pump. Call Tripp and ask where! 505-883-8388
Old Mar 30, 2005 | 11:26 AM
  #115
LittleMT's Avatar
LittleMT
VP's Import is a special blend and tough to find. There is a gas station that sells Trick 101 off of Juan Tabo, but that gas pales in comparision to VP's Import......
I am going to have to invest in a drum of this Elixar of the Gods....
Old Mar 30, 2005 | 11:46 AM
  #116
Speed Dreams
.................LOL..
MT, usually we stock VP 103 unleaded, sorry I'm out right now. In the mean time try Edwards Engines on 2nd ST.
Old Mar 30, 2005 | 03:38 PM
  #117
350zDCalb's Avatar
350zDCalb
builtZmotors
you and tripp should play patty cake together...
reminder: this is a 350z forum (you have a neon)
"the track is for racers'
not sure what you are implying, when i went out to the dragstrip, that was my first time EVER racing in a straight line against the clock...and on street tires, i still ran 13.04 @ 114mph...i didn't think that was too bad for my first time there
i have much more experience on road coarse tracks..IMO, that is what REAL racing is about..going in a straight line gets a bit boring, after 5 runs, i was done...
we'll go on a road coarse sometime little MT, there is supposedly one in town, please let me know if you know where it is/ or what days it is open to whomever
Tripp: you can chime in too- you probably know the tracks preety well out here...and, from the looks of it, you will be at the 350z meet at jason's bar, so i'll see you then buddy!
TODD
Old Mar 30, 2005 | 07:23 PM
  #118
Speed Dreams
Todd,
Your a piece of work, you insult me then want information.....????
For what it's worth, Sandia Motorsport Park is located south of I-40 and 9 mile hill. Very tight course and not very large, I think 1.65 mi.
FYI, forced inducted cars don't fair as well there as all motor does, not enough time to spool up. I believe M3 and Z06 have the fastest times there.
As I said, this is a demanding track. The last guy I went racing with pushed his 500hp Vette into the tires, 7K in repair.
The track is normally rented, Speed Dreams will have an event probably in late May or June there for the entire day. Details, classes, flyers and such will be available in the near future as we put the sponsorship list together.
I suggest asap after you get your car street worthy to upgrade your suspension..( Tien, JIC ) Also if you plan to play on the track big brake kit, trany cooler, wheels and tires...I have done my suspension first and It makes a huge difference.
So if your up to it, we will see you there, if I get track time sooner I will post date for those who would like to join.
MORE INFO SEE www.sandiamotorsports.com
Old Mar 30, 2005 | 07:26 PM
  #119
350zDCalb's Avatar
350zDCalb
builtZmotors
Todd,
aww come on...don't be so sensitive...we're playing around here
thanks for the info though...much appreciated!
TODD
Old Mar 30, 2005 | 07:55 PM
  #120
350zDCalb's Avatar
350zDCalb
builtZmotors
Exclamation The Count Down...updates
This is how she looks as of earlier today...
the egt sensor is in place, tough to see in this pic...mounted in downpipe...helix test pipes going on
...radiator in...
aam fuel system all in place
from here, the hoses/intercooler piping goes in, exhaust gets all connected...fluids filled...and then IT'S ON!!!
friday...wishful thinking...saturday..possibly...early next week...should be starting to put miles on my car preparing for my dyno
TODD
