What wideband air/fuel for the Vortech?
check this out, its pretty cool, new from innovative.
http://forums.bhamracing.com/showthread.php?t=22313
http://www.mvpmotorsports.com/Templa...149&SearchYN=N
check that page out.
ha, ive got some old pics at home but nothing new, i dont think you want to see it now, it looks stock, its going thru a semi-transformation, new wheels, lip, taking the vortech off and going with turbonetics ( when and if it comes out ).
I would have to say the AEM or the Zeitronix. If you don't mind a digital read out then I would go with the Zeitronix. Can hook up a EGT, Boost, AFR and other stuff all on one display. For my soon to be installed Vortech I order that plus a fuel pressure and a oil temp for the A piller
Input/Output range
Lambda 1.43 to 0.64 Wideband
AFR 21.0 to 9.5 Wideband
Vacuum 25.5 in Hg
Boost 25.5 PSI
EGT 200C to 1200C
Analog Wideband Output 0 - 5V
Throttle Position 0 -100 %
RPM 0 - 10,000
User Input
Thats what it does. To run the boost or EGT you have to buy optional sensors/probes for that.
Vacuum 25.5 in Hg
Boost 25.5 PSI
EGT 200C to 1200C
RPM 0 - 10,000
User Input
350Z_Al
Oct 29, 2020 07:44 PM
seagrasser
Oct 11, 2015 03:27 PM
