Fuel Injectors help????
Old Mar 31, 2005 | 11:10 AM
ForceInduction's Avatar
ForceInduction
Question Fuel Injectors help????
Hey guys I need a little help. I'm looking for some fuel injectors that are 440cc or higher that is a direct replacement for the stock injectors. This will be used for 350z that is supercharged. We do not want to use any pigtails just something that is plug and play. Does any body know the brands and sizes that will work, without having to deal with any splicing of wires?
Thanks again!
Old Mar 31, 2005 | 12:08 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Thanks again!
PE injectors are plug and play, they are quite expensive when compared to RC and other brands. A set of PE injectors is roughly $800-900, vs. about $530 for RC. PE makes terrific injectors, but they are also hard to find in stock. They come in 380cc and 510cc for direct fitment.
Gurgen is using the 510's in his car, and loves them.
Old Mar 31, 2005 | 01:39 PM
ForceInduction
Thanks! I heard rumors about the RC 510cc being a direct replacement...is this true?
Old Mar 31, 2005 | 01:44 PM
SungNamZ's Avatar
SungNamZ
Might try www.gruppe-s.com if and when you are ready to purchase. They handle PE's and as the above post said the price is going to be somewhere between $800-$900.
Old Apr 1, 2005 | 03:44 AM
zbicklin's Avatar
zbicklin
I'll sell you my PE 380cc injectors for $500. Only had 300 miles on them and then went to 440cc RC Injectors because I run a 3.12" pulley and AAM return fuel system.
Old Apr 1, 2005 | 05:08 AM
Gman2004's Avatar
Gman2004
How the car running with the 3.12? Any dyno numbers?
Old Apr 1, 2005 | 05:19 AM
zbicklin's Avatar
zbicklin
I'm going to dyno in a couple weeks. My stock Vortech with the 3.33" was 360whp, so I'm hoping for somewhere close to 400whp.
Old Apr 1, 2005 | 06:50 AM
Sharif@Forged
Forged Performance
RC doesnt make 510 saturated injectors...unless they are custom...and they are not a direct fitment. The PE 510's ARE a direct fitment.
Any time you use RC injectors, you need to buy the injector harness clips for about $10 each. If you already have 440cc RC's from the Greddy kit, then you can upgrade to larger RC injectors without needing the clips..becuase you already have them!
Old Apr 1, 2005 | 08:29 AM
ForceInduction
Thanks for all your help on this guys! We decided to go with the 510cc from PE.
