Vortech SC Question?
Old May 13, 2005 | 03:27 AM
Rickz's Avatar
Rickz
Default Vortech SC Question?
I was wondering if a Vortech SC can be installed using a JWT oil pan spacer drilled for the oil return instead of drilling that hole in your engine.
thanks
Old May 13, 2005 | 08:27 AM
Rogue350z's Avatar
Rogue350z
!!HR TT!!
I drilled my oil pan. I have heard theat most people believe it is not a good idea to drill the spacer.
Jeremy
Old May 13, 2005 | 08:33 AM
teh215's Avatar
teh215
I would advise against it since that places the return below the oil level. The Vortech oil return is a gravity feed and this will impact the flow of oil back to the pan.
Another issue, although I can't see how it would happen, is that the return hose could act like a pickup if somehow the oil flow was momentairly reversed. This would introduce unfiltered oil into the SC which is not good.
Old May 13, 2005 | 09:17 AM
xxlbeerZ's Avatar
xxlbeerZ
You can do it, but someone told me you have to make a j-pipe to the spacer above the oil level.
Didn't seem worth it to me. If I had gone Vortech over APS Single Turbo I would have just drilled the oil pan.
Old May 15, 2005 | 01:36 PM
EnthuZiast's Avatar
EnthuZiast
Guess whose back, back again...
You can also get an APS oil pan and bypass the whole drilling thing
It also holds 1 quart more oil.
Old May 15, 2005 | 04:51 PM
Gman2004's Avatar
Gman2004
I read you bought an APS oil pan from dyno comp. Do you know if have any more in stock.
Old May 15, 2005 | 06:46 PM
Rickz's Avatar
Rickz
Thanks guys I am still looking into this, im still not sure. I think the level of the oil pan with the spacer is low enough for gravity flow and will not back up. I mean if you are punching it the oil pressure raises so much that it might be better to have that extra oil and return. Just a thought.
Thanks Rick
Old May 15, 2005 | 07:18 PM
EnthuZiast's Avatar
EnthuZiast
I think DynoComp can get them fairly quickly. Mine was in stock that I know for sure.
Old May 16, 2005 | 02:14 AM
arcada's Avatar
arcada
How much is DynoComp charging for the sc install.
Thx.
Old May 16, 2005 | 08:45 AM
EnthuZiast's Avatar
EnthuZiast
They will try and keep it under 10 hours just for the install. They will most likely be making improvements over the stock install route.
Thats @ 89.00 per hour but I am buying several extras:
APS OIL PAN
AEM WB02
HKS BOV
bunch of other parts and etc.....
Old May 16, 2005 | 11:56 AM
Phatmitzu's Avatar
Phatmitzu
APS OIL PAN
AEM WB02
HKS BOV
You are using a HKS BOV on your Vortech? how does that work? I have only seen people with GReddy S's.
350Z_Al
Oct 29, 2020 07:44 PM
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
