What is Lambda? (Zeitronix)
Old May 29, 2005 | 11:20 AM
Madelinot's Avatar
Madelinot
Default What is Lambda? (Zeitronix)
Just like the title says, what are the Lambda values displayed on the Zeitronix?
Old May 29, 2005 | 11:41 AM
SpeedDreamTuner's Avatar
SpeedDreamTuner
Lambda is a A/F value of 14.64. So when you have a value of .8 lamba, you have:
14.64 x .8 = 11.71
Old May 29, 2005 | 01:10 PM
Royal_T's Avatar
Royal_T
why do they show both? (A/F, and Lambda)
Old May 29, 2005 | 01:19 PM
booger's Avatar
booger
I dont know why . But A/F is more easily understood when looking at it as you are running down the road
Old May 29, 2005 | 03:01 PM
Madelinot's Avatar
Madelinot
All right, thanks guys..
Old May 30, 2005 | 07:30 AM
SpeedDreamTuner
Why do they have kilometers per hour? Or millimeters for that matter? Some software platforms have the fuel tables set in lamda. For example the SCT stuff for Fords, uses all lambda calculations, where CMR uses actual fuel tables.
Old May 30, 2005 | 12:00 PM
Royal_T's Avatar
Royal_T
I see your point, I really did not look at it that why, but now I understand.
Thanks
Old May 30, 2005 | 09:33 PM
uplz4588's Avatar
uplz4588
i thought lambda was the A/F sensor before the cats? like the sensor in the headers
Old May 31, 2005 | 03:21 AM
Madelinot's Avatar
Madelinot
Yes, that's what we're talking about. There is a sensor in the downpipe BEFORE the cat and one AFTER the cat, on each side (total of 4). Lambda is the same thing as A/F ratio, just a converted value. It makes a lot of sense now that I think about it, I'm just not sure why they would bother showing both. It would be nice if the Zeitronix display was configurable.
Later,
Old Jun 1, 2005 | 03:17 PM
uplz4588's Avatar
uplz4588
^ ok thanks i just got a little confused
Old Jun 1, 2005 | 03:33 PM
sentry65's Avatar
sentry65
the burninator
yeah if zetronix wanted to make their gauge really useful they'd replace lamda with fuel pressure or oil temp
Old Jun 1, 2005 | 04:25 PM
azrael's Avatar
azrael
They show both because lambda is a measurement relative to stoichiometric ratio for the type of fuel you're using.
For non-oxygenated gasoline, 1.0 lambda happens to be ~14.7:1.
For methanol, 1.0 lambda would be 6.4:1.
For other types of fuel, the stoichiometric ratios are different. Lambda allows you to measure air/fuel ratio independent of fuel type.
Beware that if you do run a different type of fuel, the meter would need to be recalibrated for the fuel type you are using. The meter cannot correct automatically.
Old Jun 1, 2005 | 04:31 PM
sentry65's Avatar
sentry65
the burninator
BTW I'm selling my brand new, never used ZT-2 w/LCD screen
originally bought it to monitor my A/F for NA
I'm getting individual gauges for FI
aalzuhair
Jan 31, 2006 06:42 AM
backagain
Jul 21, 2005 12:40 PM
CaneZMD
May 22, 2004 12:16 AM
