What mods are recommended before going FI?
Old Jun 11, 2005 | 08:10 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Originally Posted by nis350ztt
Yeah, I knew that much, but I thought the boost was controlled through the ECU as well. Either way, I PM'd him right after my last post about it.
the boost control sensing line for the wastagate hooks directly to the compressor housings and contols the boost pressure. the ECU is controlling the fuel and ignition curves based on the testing and calibration we have done over the past year of development.
the ECU does not control the boost.
Brad
That was his response.
So yes, you would still need a boost controller.
Old Jun 11, 2005 | 08:13 PM
Jaki's Avatar
Jaki
Originally Posted by nickgundara
Does a Y-pipe help anything on a twin turbo install?
Not sure what u meant by "on install," but the Y-pipe lets your car breath a little easier. If you're keeping the stock exhaust then I would suggest to get the Y-pipe, mid-pipe, and test pipes. But I would really suggest to get a complete new exhaust system and some test pipes or high flow cats.
Old Jun 11, 2005 | 08:15 PM
Brandon@Forged
Depends, if it is larger than OEM, yes it should. I would think you woudn't see true benefits until you replace with a y-pipe-back exhaust and test pipes.
Old Jun 11, 2005 | 08:22 PM
Brandon@Forged
Originally Posted by Diesel350
I'm looking at the ST. Not looking to go over 400rwhp.
Then APS and/or Turbonetics will have everything included. The only other thing I could think of is maybe a return fuel system (if you get a Turbonetics).
I don't really have anything else to recommend for going turbo. The only other thing I would tell you could get are a crank pulley, y-pipe-back exhaust (preferrably 3"), etc.
Old Jun 11, 2005 | 09:02 PM
Z BOY's Avatar
Z BOY
so far in this thread, you experts have been addressing prep for a turbo setup, but what about a supercharger at only moderate hp increases? would your recommendations be different, and if so, how, pls?
Old Jun 11, 2005 | 09:06 PM
nickgundara's Avatar
nickgundara
If there is already a cat back exhaust installed with test pipes, does a larger Y-pipe help any on a twin turbo set up? Please forgive the newb questions....
Old Jun 11, 2005 | 09:08 PM
Brandon@Forged
Moderate is about how much? 340? Pretty much depends on the kit.
Brandon@Forged
Cat-back or Y-pipe-back? If it's a cat-back then you don't have a y-pipe.
Old Jun 11, 2005 | 09:09 PM
Z BOY's Avatar
Z BOY
ya, less than 350hp.
Old Jun 12, 2005 | 08:04 AM
Shabib67's Avatar
Shabib67
Im confused. With other cars lets take for example a 240sx wtih a sr20det you have the turbo extension, downpipe, midpipe and then the catback. What would you have to replace with the 350z. I want the RSR ex mag2 exhaust and test pipes would i need to get anything else like downpipes?
Old Jun 12, 2005 | 10:57 AM
Brandon@Forged
Here's a diagram...
And of course there are variations of each.
With TT, the turbo is mounted between the exhaust manifold and test pipe(s).
Old Jun 12, 2005 | 11:23 AM
Z BOY's Avatar
Z BOY
isn't a better description of your second diagram a "true dual" exhaust?
a cat-back exhaust can also have a ypipe, ala oem and nismo setups, right?
Old Jun 12, 2005 | 11:28 AM
Brandon@Forged
Yes. Some y-pipe-back exhausts include the Y-pipe and some don't.
Old Jun 12, 2005 | 06:29 PM
Diesel350's Avatar
Diesel350
So would the Fuji exhaust and aftermarket y-pipe be a good setup with the APS ST?
Old Jun 12, 2005 | 06:46 PM
g356gear's Avatar
g356gear
The APS ST does not use a y-pipe. It hooks up where the former y-pipe meets the mid section of the exhaust.
ReavTek's Avatar
ReavTek
The ST setups are a little different. They eliminate the Y-pipe and cats completely with a single straight pipe. Unfortunately, this means I will be selling my Y-pipe soon... :/
Old Jun 12, 2005 | 07:32 PM
Brandon@Forged
Yes, note that Turbonetics has a cat-option though.
Both use stock headers as well, though either one can be used with aftermarket headers (assuming they'll clear the piping) (and APS offers a cast manifold if you want that for an extra cost).
Old Jun 12, 2005 | 10:34 PM
  #38
cloudy's Avatar
cloudy
Also might i note that if anyone is planning on going with Greddy TT's. That several have blown engines, even with some of these mods that nis350ztt said to do. APS TT would be your safest best if u want a TT. Mainly because you dont sound like you know too much about the Z engine, and want some reliable 400rwhp. With the APS TT you dont need to upgrade anything else out of the box to get 400rwhp reliable.
Old Jun 12, 2005 | 10:35 PM
  #39
cloudy's Avatar
cloudy
Oh and my other suggestion, READDDDDDDDDDDDDDDDDDDD. Just read almost EVERYTHING in the F/I section. Its how you learn.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
apex locator
Jul 23, 2021 02:27 AM
Tochigi_236
Sep 27, 2015 03:40 PM
