The Turbonetics S/T is in and MAN what a rush!!!
Old Jul 18, 2005 | 08:25 AM
  #121
MIAPLAYA's Avatar
MIAPLAYA
I heard HKS makes a device that converts a MAP signal to a MAF signal to feed the ECU....Not sure on the details. Something I heard on the Sentra boards....
heres the link from HKS... http://www.hksusa.com/products/?id=858&rsku= not sure if it will work or not...
Old Jul 18, 2005 | 11:20 PM
  #122
Speed Dreams's Avatar
Speed Dreams
Researching that,thanks Rob.
Old Jul 19, 2005 | 08:15 AM
  #123
MIAPLAYA's Avatar
MIAPLAYA
No problem....HOpe that works as advertised. If so that would be a nice device. I read a little more on it last night and it looks like you add a IAT sensor and MAP sensor and you can also add a Super AFR or GCC and fine tune the curve precisely as you want.....
Old Jul 19, 2005 | 09:40 AM
  #124
SSR Engineering's Avatar
SSR Engineering
Why not try the MAP ECU, alot of people are having a hard time finding VPC's.
Q. Can I install the MAP-ECU myself, there are only a few simple connections?
A. Yes, but you should have a professional performance tuning specialist
tune the unit.
Q. How do you get a performance upgrade with the MAP-ECU?
A. Two ways: Firstly you remove the AFM, which can be a restriction, especially if you have increased boost, etc. Secondly you are able to tune the Air/Fuel ratios for your engine. The tables in most stock ECU's are compromises for the variations in thousands of production cars. This means it is not tuned for your engine, especially if you have made changes around the engine for performance. Most stock tables are also very rich to prove a safety margin for the manufacturer against warranty claims. The MAP-ECU allows you to tune the Air/Fuel ratio for optimum performance for your engine.
Q. What kind of performance gain can I expect with a MAP-ECU?
A. That depends on your engine, it's condition and what modifications, if any, you have made. A Toyota 3S-GTE gained 30kW's at the wheels in a back-to-back dyno run comparing the stock AFM with a tuned MAP-ECU configuration, with no change in boost.
Q. Will the MAP-ECU work on non-turbo cars?
A. Yes, it will. There is no reason why you cannot install a MAP-ECU in a naturally aspirated car so you can remove the AFM and gain complete control over fuel delivery. In fact, you can order the unit with expanded vacuum sites in the table especially for NA engines to improve tuneability.
Old Jul 19, 2005 | 09:41 AM
  #125
MIAPLAYA's Avatar
MIAPLAYA
Got a link to that?
Old Jul 19, 2005 | 09:44 AM
  #126
SSR Engineering
Got a link to that?
http://www.performancemotorresearch.co.nz
Old Jul 19, 2005 | 11:25 AM
  #127
kcobean's Avatar
kcobean
Turbonetics has verified the flash to be good on my car. They are going to reflash it anyway and send it back. The result is that there is still something wrong with the car that is undiagnosed, and I am the only one with this kit to have had this problem to date.
Old Jul 19, 2005 | 11:38 AM
  #128
arlingtonz's Avatar
arlingtonz
lucky you
Old Sep 24, 2005 | 03:50 PM
  #129
35ounces's Avatar
35ounces
03 CS Track 6MT
did this ever get resolved?
Old Sep 24, 2005 | 04:10 PM
  #130
Zexy's Avatar
Zexy
"The HKS VPC is a fuel management device that is designed to physically and electronically replace the OEM air metering devices for improved air flow and precise fuel delivery control. OEM air metering devices, such as Air Flow Meters (Flapper/Plunger types) and Air Mass Sensors (Hot wire / Karmen Vortex types) measure the amount of air flowing into the intake manifold in order to properly control fuel enrichment levels. Aside from offering no adjustment or reprogramming options to take advantage of dramatically higher amounts of airflow or larger fuel injectors, the OEM air meter also represents a significant restriction to the intake system. To overcome this restriction, the VPC physically removes the OEM air meter to dramatically improve airflow capacity and converts the system to what is referred to as a speed density system. By utilizing a 16-bit central processing unit, the VPC reads it’s own intake air temperature sensor and absolute pressure transducer (B-MAP sensor) signals and then converts those signals to one that is recognizable by the factory ECU. The VPC also incorporates the ability to upgrade the internal application specific ROM program to correctly compensate and take full advantage of larger, Higher flowing, HKS fuel injectors and/or the greater air flow characteristics of larger turbos. Each application specific ROM program is calibrated for a specific injector size, fuel pumps, camshafts, and/or turbos, ensuring that the correct injector pulse width is calculated to prevent driveability and reliability problems. Since the VPC “piggy-backs” the factory ECU, all factory systems are still intact and operational. Fine tuning of fuel curves can be further achieved by integrating the plug-in GCC or by wiring in a Super AFR."
Seems very interesting. I wonder if they have specific applications for specific cars(maybe need a specific harness). They also have a couple on EBAY.
Anyways i think it is not needed to sort the issue out. The rest of the TN cars with properly tuned MAF have no issues(taurran). This one should be no different? Just my 2cents
Old Sep 24, 2005 | 07:26 PM
  #131
kcobean's Avatar
kcobean
What a completely non-sensical statement. Care to share with the rest of us what a properly tuned MAF is, and why it's not needed to sort the issue out (Perhaps because it's not your car?) You're right, my car SHOULD be no different but it is, and I'll bet you I'm not the only one.
35ounces, you have PM. Basically, no this was never resolved. Turbonetics, AAM, and another shop all looked over this (Turbonetics as much as they could from 3000 miles away) and nobody could figure it out. The install was checked and re-checked, the ECU was flashed, reflashed and verified, and nothing turned up. Fuel pressure is good, no boost leaks, everything checks out. Maybe it's my "untuned MAF". I'm preparing to install an EU and a boost controller on the car to rectify the issue. My car is still making 370/370 on the dyno, but I want to make that power with proper boost and A/F ratio, which is something I'm not doing right now. I'm seriously considering driving the car down to NC and asking Sharif to fix this once and for all.
Old Sep 24, 2005 | 08:20 PM
  #132
Zexy's Avatar
Zexy
I'm sorry. Forget my last statement. I meant TN cars using OEM MAF with no modifications to it(like possibility of using the HKS VPC like some of us just discussed.) I meant if others do not have this current issue that your car has, that some stated it is weird/unique, then yours should be no different. Maybe it's just the need of keep troubleshooting elsewhere around the car so I think the MAF may not be the problem and additional MAF eliminating/modifying devices are nt needed. I never meant to offend anybody, i know it's not my car, i'm not trying to add negativity on posts as they highly educate me, i am not trying to compete with other people's knowledge, and i do think the TN kit is great . I was just giving my 2cents. Sorry if i have offended you as well.
Old Sep 24, 2005 | 08:34 PM
  #133
kcobean's Avatar
kcobean
I'm sorry. Forget my last statement. I meant TN cars using OEM MAF with no modifications to it(like possibility of using the HKS VPC like some of us just discussed.) I meant if others do not have this current issue that your car has, that some stated it is weird/unique, then yours should be no different. Maybe it's just the need of keep troubleshooting elsewhere around the car so I think the MAF may not be the problem. I never meant to offend anybody, i know it's not my car, i'm not trying to add negativity on posts as they highly educate me, i am not trying to compete with other people's knowledge, and i do think the TN kit is great . I was just giving my 2cents. Sorry if i have offended you as well.
I see....sorry too for the frustrated response, it's just that from a performance standpoint, my car was basically stock prior to the Tnetics kit and I spent probably close to an additional 1K in 'troubleshooting fees' to try and solve this. While we haven't installed a different MAF sensor on the car, I think we've pretty much eliminated the MAF system as the culprit. Unfortunately, that elimination hasn't brought to the surface anything else.
Again, sorry I mis-took your post.
Old Sep 24, 2005 | 08:51 PM
  #134
Zexy's Avatar
Zexy
Although i say the OEM MAF and it's function may not be the problem, the unit itself may be faulty for some reason, so i'd still install a different unit to see what happens.
What other reasons do you think the MAF may not be the problem? Just curious.
Old Sep 24, 2005 | 09:06 PM
  #135
kcobean's Avatar
kcobean
The reason for discounting the MAF sensor itself as the culprit is that when my car was N/A, my A/F was normal, per the dyno. Normal when N/A means normal when F/I.
I haven't heard of a malfunction in a MAF sensor where it provides improper voltage that didn't affect the idle, and my car's idle is rock solid.
Old Sep 25, 2005 | 09:11 AM
  #136
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Hi Kelly, just let me know when you are ready.
I think ZEXY is talking about the electronical limitations of our MAF. I too feel that your MAF is fine, and not malfunctioning. The ECU is very sensative to anomolies in the MAF voltage, and any erratic behavior will immediatley throw a CEL. The MAF is the KEY sensor that the ECU uses to control the engine, along with TPS, and both of these senors are very sensative to abnormal changes in voltage.
The EU will quickly and easily solve the tuning issue, provide that there is no mechanical issue with the car. Sounds like your shops checked and double checking things like the fuel system, vaccum leaks, hose couplers, etc....so thats a good thing.
markt71Z
Aug 31, 2002 11:52 PM
mrducks
Aug 29, 2002 02:38 AM
