Considering some options...
Old Jul 11, 2005 | 09:36 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Originally Posted by nis350ztt
Also, i'm looking for some lightweight wheels (15 or 16 or 17"?), simple design, that can be wrapped into some Mickey Thomspon slicks or Hoosier slicks (not sure what size will fit) for the drag track. Any recommendations on setups I can use would be appreciated.
And also looking for a setup for autocross/road course, what size wheel should I go with, and what tires? (I heard Toyo RA1s (I believe) are supposed to grip extremely well)
Bump.
Old Jul 11, 2005 | 09:45 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Ok, cool. I guess i'll stick to the original plan.
Arias extreme-duty (8.6:1 , not sure on the bore yet, how much can you bore the Darton sleeves?
At least .040 over...and likely much more. I dont know the exact limit, but i could ask Darton for you. We can make the Arias Extreme duty in any bore size you desire.
Old Jul 11, 2005 | 09:50 PM
Brandon@Forged
Any disadvantages to going to a larger bore?
Old Jul 12, 2005 | 06:57 AM
Sharif@Forged
Forged Performance
Nope, unless you dislike more power and trq across the board.
At some point, there may be some modification needed to the headgasket, but I havent measured it to detemine what that is.
Boring doesnt result in huge displacement gains (or power gains)....that is where a stroker kit really comes in. You just need to check on the thickness of the sleeve, and the sleeve manufacturer will have a recommending overbore limit for each application. If it was my motor, I would probably go .040 and leave it at that. THat would make your 3.5L about a 3.6L.
Old Jul 12, 2005 | 09:41 AM
Brandon@Forged
Ahh, ok.
I was thinking about .040 as well.
Old Jul 12, 2005 | 10:01 AM
t32gzz's Avatar
t32gzz
Brandon, the 650whp goal seems a bit lofty. Are you planning on headwork? I know you said you were getting a longblock, so I assume you are doing heads, springs and retainers and possibly oversized valves. So far, no one outside a race team has put down an uncorrected number over 620 on pump gas. I would say shoot for 450 and maybe 600, still pushing it.
The SGP pistons are CP pistons, it is just modified to their specs. Sounds like you will be building a beast. Best of luck.
Old Jul 12, 2005 | 10:03 AM
Brandon@Forged
Yes, not at first though. After the block is built up, later on i'll get some OEM heads for them to build. Tomei 268 cams and Ferrea valve kit.
Old Jul 12, 2005 | 12:02 PM
t32gzz's Avatar
t32gzz
So the 650whp goal is later on down the road, or do you think you can get there w/o headwork?
Old Jul 12, 2005 | 12:09 PM
Brandon@Forged
Well, i'm going to try to get as close as possible without headwork (safely).
superkatt
Aug 1, 2013 09:57 PM
Moussa93
Mar 9, 2013 10:24 PM
