GReddy Type RS BOV on Vortech??
Old Jul 8, 2005 | 05:41 AM
zachcrosen's Avatar
zachcrosen
Default GReddy Type RS BOV on Vortech??
I have a GReddy Type RS BOV in my kitchen that is about to go on my g/f's SRT-4. I was wondering if this would work on the Vortech in place of the Maxflow Bypass Valve. I have heard that the RS is a replacement for the S. In case you havent heard, I am having boost problems. I am not boosting but 5 psi and I should be boosting around 8 psi I think. Several shops to include Autolabz, Z1 Motorsports and GSC Motorsports have suggested that the problem may be a bad bypass valve. So that is why I am wanting to try this.
I am thinking on the Maxflow unit, there are 2 vac lines running to it and on the GReddy, there are ONLY 1. I am not positive though. f this is in fact the case, which ones connect to the GReddy BOV?
TIA,
Zach
Old Jul 8, 2005 | 06:00 AM
Jaki's Avatar
Jaki
I believe that on the vortech you can only run a circulating BOV. The Type RS is not a circulating BOV so it cannot be run on the Vortech. However, the Type S can be fitted to run on a vortech. That is what I have read in a thread a while ago when one member bought a Type RS Bov and then found that u can only run circulating bov.
Old Jul 8, 2005 | 07:54 AM
backagain's Avatar
backagain
contact freezeg35 on the board, he is running the greddy type s on his z with vortech.
Old Jul 8, 2005 | 01:13 PM
booger's Avatar
booger
I couldnt get it to work . Some say they have . I didnt remove one of the springs inside of it , and that maybe the fix to get it to work . No one has come foward to say how they got it to work yet .
Old Jul 8, 2005 | 01:47 PM
teh215's Avatar
teh215
TIA,
Zach
I don't recall 2 lines on mine when I installed it .... ?
Old Jul 8, 2005 | 02:45 PM
Jaki's Avatar
Jaki
I will have a Type-S for sale in few days, pm if you're interested.
Old Jul 8, 2005 | 06:08 PM
freezeg35's Avatar
freezeg35
I just slaped it in and that was that. Still have at whistle at 1500 rpm on decel, other than that its a nice looking bov lot purdyer than the maxflow
Old Jul 8, 2005 | 06:18 PM
SSR Engineering's Avatar
SSR Engineering
I'm pretty sure there is a re-circ fitting for the Type RS BOV
Old Jul 8, 2005 | 06:56 PM
narkotic's Avatar
narkotic
The maxflow is a bypass valve, a noisemaker for the vortech system...
The RS is a blowoff valve that will not work with this application. The type S has two ports, one for blowoff and one for bypass.
Old Jul 8, 2005 | 08:15 PM
zachcrosen's Avatar
zachcrosen
Yeah, I was mistaken. Only 1 line
Old Jul 8, 2005 | 08:17 PM
zachcrosen's Avatar
zachcrosen
So I dont guess anyone knows for sure if it will work. Will it cause any harm to the system if I do the install? I called and talked to Matt @ Altered Atmosphere and he said it would work but I don't know. How will I know if it doesnt work properly?
Old Jul 8, 2005 | 10:21 PM
freezeg35's Avatar
freezeg35
I dont think the rs will work. I know the type s does.
Old Jul 9, 2005 | 04:49 AM
zachcrosen's Avatar
zachcrosen
Why wouldnt it? How would I know if it doesnt work?
Old Jul 9, 2005 | 07:38 AM
narkotic's Avatar
narkotic
The RS WILL NOT WORK with the vortech. It is a blowoff valve that only opens under boost.
The supercharger needs a bypass valve that is open even under decel (vacuum).
Old Jul 9, 2005 | 07:53 AM
booger's Avatar
booger
Zach..if they preasurized the system they probably did it before the BOV . And they would have noticed if it leaked or not . With headers , test pipes and Stillen dual exhaust , with the stock pulley I saw 6 psi , I put on the 3.12 pulley and got 7psi . I got tired of the loud exhaust and put on Crawford cats . I got over 9psi after that . Later on I did find a leak in my plenum when I did the preasure check
Old Jul 9, 2005 | 07:56 AM
zachcrosen's Avatar
zachcrosen
I know what all you have told me in the past. I just have a BOV on hand now and was wanting to bolt it up and run the car just for ***** and giggles to see what happens. Just to ensure to myself that the bypass valve is not the problem.
Old Jul 9, 2005 | 08:11 AM
booger's Avatar
booger
I tried that also . It will not open under vacuum and it will screw your tune up .
350Z_Al
Oct 29, 2020 07:44 PM
sales@czp
Sep 23, 2019 03:30 PM
