Possible to go into limp mode with being too rich ?
Old Jul 8, 2005 | 07:21 PM
backagain's Avatar
backagain
Default Possible to go into limp mode with being too rich ?
my car is running extremely rich right now, my wideband just stopped working but for the past few months i have been running around 9.9 -10.5 a/f ratio gauge from 2k to 6600 rpm's durring a WOT run. car goes into limp mode every so often. hasn't done it in a while, while my wideband isn't working right now, i hooked up a narrowband gauge just to see if it still goes full rich, and it does, car went into limp mode in 2nd gear around 4k rpm. a thought just popped in my head, would being too rich cause an engine to possibly not burn all the gas in the cylinder and cause the car to go into limp mode ? the car just started doing this when it was riched up from being too lean when exhausts were changed out in feb. any thoughts ?
thanks
Old Jul 9, 2005 | 05:34 AM
CpraceZ's Avatar
CpraceZ
Sounds like the split second box to me, if there is something wrong with the wiring, or the box has something wrong with it, it will go into limp mode and run extremely rich I would check over the wiring, if everything looks good I would maybe check out that black box. If you have any question feel free to email me or PM me.
Old Jul 9, 2005 | 08:42 AM
backagain's Avatar
backagain
well, its programmed rich right now on purpose, just wondering if the car being too rich would cause limp mode.
Old Jul 9, 2005 | 08:55 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Too rich, in itself, will not cause limp. It will cause your ECU to throw all kinds of CEL's, but not a pure limp mod per se.
I am with CP on this one....check your split second box and wiring.
Old Jul 9, 2005 | 09:53 AM
backagain's Avatar
backagain
all looks good. possibly under heavy accelleration a wire is coming out of contact and causing a fuel cut ? this would be VERY bad wouldn't it ?
Old Jul 9, 2005 | 10:36 AM
CpraceZ's Avatar
CpraceZ
It could be a wire coming out of contact which would cause the car to go into limp mode but once it goes into limp mode it should not go into high RPMS at all, I have also seen these split second boxes do weird things you might just need a reflash on the box.
Old Jul 9, 2005 | 12:20 PM
backagain's Avatar
backagain
hmm, may take out the ecu harness and soder in the wires, they use clip on wire connectors now.
Old Jul 9, 2005 | 02:15 PM
booger's Avatar
booger
I would for sure do that . I had my Zeitronix wired in with clips . Screwed with every thing , I couldnt get it to idle right most of the time , would go real rich and bog down .
GET RID OF THE CLIPS
Old Jul 9, 2005 | 02:38 PM
kcobean's Avatar
kcobean
My car w/ Turbonetics is going all the way down into the LOW 9's between about 4500 and 6200 RPM. Threw a bunch of CEL's, but never went to limp mode.
Old Jul 10, 2005 | 11:19 PM
Speed Dreams's Avatar
Speed Dreams
Might be maf issue if your sure the care is rich.
Old Jul 11, 2005 | 06:26 AM
Sharif@Forged
Forged Performance
MAF irregularities typical show up as CEL's. Not always...but typically. So far, we've seen very few, if any, damaged or suspect MAFs in VQ V/I motors.
You can scan MAF voltage, via scantool, and look any annomolies...just to double check.
Old Jul 11, 2005 | 07:45 AM
backagain's Avatar
backagain
it's weird, it may happen 1 out of every 20 times, never in first gear, always in 2nd or 3rd,
Old Jul 11, 2005 | 07:46 AM
CpraceZ's Avatar
CpraceZ
deff soder the wires we have found that just using clips and connectors is not a good enough connection with the SS box. Feel free to shoot me a call if you need any help or have wiring issues, if you take the box out you may want to just shoot it over to Vortech and have them check it out.
Old Jul 11, 2005 | 09:17 AM
Rogue350z's Avatar
Rogue350z
!!HR TT!!
Same thing happened to me today in 3rd about the 5 or 6 th time it has happened. My car varies between to rich and to lean and it always happens when rich. I have the Vortech as well.
Jeremy
Old Jul 11, 2005 | 11:16 AM
overZealous1's Avatar
overZealous1
does the car light the cel when this happens or no? i had alot of probs with my ati from running 15psi and not cutting signal to the maf. i wouldn't get the service engine soon light on but the car would all but just die on me. would not happen in 1st but usually 2nd and 3rd.
Old Jul 11, 2005 | 12:44 PM
backagain's Avatar
backagain
no cel, just goes into limp mode, car doesn't die, just won't rev past 2500 rpm or so. turn car off, back on , car runs great.
Old Jul 11, 2005 | 02:11 PM
overZealous1
ya kinda sounds like the exact thing mine was doing. turn car off, wait a few seconds, turn back on and good as new (well atleast till the next time i got into it) mine would do it fairily consistantly. you might want to do a search on the subject and try clipping the maf. pretty cheap to do and easy. that was the concensus we came to that i was sending to many volts to the ecu at too low an rpm.
i feel your pain though, it would really **** me off when it would happen to me cause it only does it when you are trying to go fast or race someone and your car just cuts out, made me feel like a dick, lol.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
etkms
Jun 19, 2022 06:30 PM
aarrgghh
May 1, 2022 11:04 AM
ddegrande21
Sep 6, 2015 11:15 AM
