harldy any boost and loud noise! HELP!
Old Aug 5, 2005 | 05:13 AM
mazx6's Avatar
mazx6
Default harldy any boost and loud noise! HELP!
I took a friend of mine for a ride yesterday and noitced when i got in to boost it was REALLY loud. I thought "**** i have an exhaust leak". By the time i got back to my house and couldn't get full boost any more (5.6psi) the highest i could get was only like 3.9 psi. I also notice the BOV is not sounding like it used to, even a 0psi at 0 vaccum the BOV would sound now it doesn't. In 2ed gear its so loud now it sounds like a supra with a open loop Wastegate. 3ed gear it sounds more like a MAJOR leak maybe in one of the cuplings or something. Its pissing me off, before everything worked fine, boost to normal level no problem. Kind sounds like its coming from underneath the car maybe. Anyone ever had this problem? Its a Greddy kit.
Old Aug 5, 2005 | 06:16 AM
theking's Avatar
theking
definitely sounds like a vacuum leak.
Old Aug 5, 2005 | 06:37 AM
mazx6's Avatar
mazx6
vaccum leak as in a line or a major area like a wastegate or coupling.. please guys help i'm at work and i'm trying to get some ideas on what it is for when i get home
Old Aug 5, 2005 | 06:44 AM
overZealous1's Avatar
overZealous1
gunna have to check all your piping for leaks. from what you are describing it should be pretty easy to find.
Old Aug 5, 2005 | 06:53 AM
mazx6's Avatar
mazx6
yea i think so, i really hope its obvious to find, the way it sounds under wot, it should be. thanks guys for the help.
Old Aug 6, 2005 | 05:10 PM
mazx6's Avatar
mazx6
MAN!!! DARRRNNNNIITT! i'm just so pissed i spent an hour on what i thought was the leak. The passenger side turbo look like the compersor coupling to intercooler pipe was loose. I tightened the clamps down and nothing got better, man it was hard trying to get to those things. A vaccum line wouldn't produce that kind of noise would it? No way.. I mean its loud. Any ideas?
Old Aug 6, 2005 | 06:03 PM
westpak's Avatar
westpak
SFZCC
Definetly sounds like a boost leak somewhere, most like a coupling as mentioned.
A vacum leak would sound at all time even idle, a boost leak would sound when boosting and would keep you from building boost.
Old Aug 6, 2005 | 06:36 PM
kcobean's Avatar
kcobean
I've heard more than one person say they popped a coupling at the intercooler and that their car was quite loud as a result...Just a thought.
Old Aug 7, 2005 | 08:09 AM
mazx6's Avatar
mazx6
yea i check all clamps, man, i must say the shop that installed this kit didn;t do the best job... ALL of the clamps where only on there hand tight, but i did trace it down I THINK to the intake housing -to- intercooler pipe, the one thats about impossible to get to. I guess i'm going have to go back and take a bunch of stuf of to get to and try to push them in to the cupling better. And one else know an easy way to get to it?? thanks for the replys.
Old Aug 7, 2005 | 08:41 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
What plenum are you running? I would check around the throttle body and plenum for leaks.
The other day, I found a large hole in my plenum...oops.
Old Aug 7, 2005 | 08:56 AM
mazx6's Avatar
mazx6
hmmm.... I'm running a stock plenum. I think i might put it up one the dyno so i can see where its coming from if i don't get it fixed tonight. Thanks for the thought Sharif!
Old Aug 7, 2005 | 02:16 PM
theking's Avatar
theking
My money is on the pipe just before the maf. That thing is pain because as the engine torques that pipe tends to twist.
Old Aug 7, 2005 | 09:22 PM
overZealous1
ya unfortunately you need to pull the front bumper to get to it. or you may be able to get at it from below if you remove the under motor plastic. good luck!
Old Aug 8, 2005 | 05:29 PM
mazx6's Avatar
mazx6
good thinking i'll check that tonight, i haven't had to to mess with it yet...
Obadabot
Jun 18, 2023 11:31 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
