5AT Vortech Dyno #'s
Old Aug 17, 2005 | 10:19 AM
350zOnJuice's Avatar
350zOnJuice
Default 5AT Vortech Dyno #'s
Hey guys whats up, just wanted to post up my #'s since I promised some of you, The car was tuned this morning.
Here are the final #'s
339.5rwhp and 291.3lbs *At The Wheels*
I was very pleased that it came out with those #'s as the car is running safe and can be at WOT time after time without any problems.
Air Fuel Of 11/12 through the charts
With that being said, Im 5AT so i guess its not bad at all!!
Old Aug 17, 2005 | 10:34 AM
KraftG35's Avatar
KraftG35
Nice. i'm having mine installed on my 5AT in a few weeks so I'm hoping for those numbers if not better.
What other mods other than SC do you have? Any breather mods?
Old Aug 17, 2005 | 10:38 AM
g8tor20's Avatar
g8tor20
Hey Juice...Just sent you a PM. Mine goes in sometime next week and I'll report my numbers too.....
Old Aug 17, 2005 | 10:42 AM
350zOnJuice
as for mods,I just have stillen exhaust
Old Aug 17, 2005 | 10:54 AM
jpc350z's Avatar
jpc350z
What type of dyno was it done on? Some variation between load based and inertia type machines..About 10-15 % with the inertias resulting in higher output's..
Old Aug 17, 2005 | 11:22 AM
booger's Avatar
booger
Glad to hear it went ok
Old Aug 17, 2005 | 04:27 PM
350Mark's Avatar
350Mark
Where are you getting it installed?
Old Aug 17, 2005 | 04:37 PM
SpeedDreamTuner's Avatar
SpeedDreamTuner
Didn't you have that lean problem? What fixed it?
Old Aug 17, 2005 | 06:27 PM
350zOnJuice
the tune fixed it , and as for the dyno it was a dynojet?
is there supposed to be an increase in power? due to the dyno
Old Aug 17, 2005 | 06:30 PM
booger's Avatar
booger
Dyno jets read 10 to 12 % more than load based dyno's
Old Aug 17, 2005 | 07:53 PM
LiNks's Avatar
LiNks
Im having my Vortech installed soon as well and was expecting a lot higher #s.....are those numbers a little low? i also have a couple of other mods to hopefully get bigger numbers
Old Aug 18, 2005 | 08:09 AM
KraftG35's Avatar
KraftG35
GRD.
Old Aug 18, 2005 | 08:26 AM
Jaki's Avatar
Jaki
Congrats again Richard.
Those are good numbers for a Vortech on stock boost with just an exhaust, especually if you consider the heat that you dynoed in and the fact that your car is AT.
Old Aug 18, 2005 | 08:28 AM
350zOnJuice
thanks, jaki
Old Aug 18, 2005 | 09:27 AM
G352NV's Avatar
G352NV
I did a install on a members car here. He had a auto and his #'s were in the 380's. Why is it that some number so so much lower then others? I see this a lot.
Old Aug 18, 2005 | 09:49 AM
350zOnJuice
Great News Guys!!!
I went back to the shop and had them tighten my serpentine belt happen to be it was loose!!! and it was slipping at boost and you couldent even hear it.
New Results Are In!!!
378.2rwhp and 332.4lbs *At The Wheels*
Old Aug 18, 2005 | 09:54 AM
SungNamZ's Avatar
SungNamZ
Nice numbers! That sepentine belt can be a pain in the azz until it gets stretched out. I finally put a 3" dia hole in the bottom the guard that lined up with the pulley adjustment bolt.
Old Aug 18, 2005 | 09:57 AM
jpc350z's Avatar
jpc350z
Originally Posted by 350zOnJuice
Great News Guys!!!
Great tq #'s . would like to see the dyno chart..
350zOnJuice
I caution you... be sure the loosen the bolt to that holds the pulley, then adjust the tensioner (which is the one you drilled a hole for) if you do not do this in steps, you damage the pulley and the bracket which secures it, if it has not happend already, hence you situation were its coming loose frequently.
hope this helps
Old Aug 18, 2005 | 09:59 AM
350zOnJuice
i will try my best, unfortunately the place where i dynoed and tuned
Twilight Performance
is good for tuning and etc, they build race cars
but robert which is the owner there has a printer with no ink!!! wtf? lol
he told me as soon as he refills he will print me the chart, he states that the dyno runs etc will be saved in his pc... I hope, lol
