TurboXS Announces the Z UTEC Release
Old Oct 3, 2005 | 03:19 PM
  #101
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Looking good! Keep it up!
Old Oct 3, 2005 | 03:42 PM
  #102
ThetunerFestNJ's Avatar
ThetunerFestNJ
What PSI you running??
Old Oct 3, 2005 | 05:28 PM
  #103
g356gear's Avatar
g356gear
The other thread said 10 psi.
Old Oct 3, 2005 | 05:34 PM
  #104
phunk's Avatar
phunk
CJ Motorsports
Originally Posted by BlackTuner
This is false information, the UTEC's knock sensing is only active if you are having a knock event. If you are having these problems your car is not tuned properly.
At any rate, here's the dyno plot of the MRC Car. I was forced to stop here since we are out of injectors.
Jermaine@turboxs.com
Great work!! This is looking like its going to be an awesome solution for Z owners.
Interesting about the fuel... supposedly the fuel system included with the APS TT kit is good for over 500whp... but like you have experienced here, my customers car was out of fuel quite a bit below 500whp. interesting...
Old Oct 3, 2005 | 06:21 PM
  #105
Zexy's Avatar
Zexy
I'll be dropping my cash on this piece.
Old Oct 3, 2005 | 07:49 PM
  #106
Gman2004's Avatar
Gman2004
Nice gains!
Old Oct 3, 2005 | 08:49 PM
  #107
mchapman's Avatar
mchapman
Nice power curve, very smooth and linear, pulling almost all the way to redline. This is quite different to most of the dynos we've seen using emanage etc.
Old Oct 3, 2005 | 09:03 PM
  #108
zero2prove's Avatar
zero2prove
I think there is something not right with the fueling system on this particular kit. Were you able to log fuel pressure? The stock APS fueling system should be able get you a little over 500whp on a Dynapack without any problems at 11.5:1 AFR. Now if you were tuning at 10:1 than I can see the injectors possibly maxing out. Did you verify that the injectors were running close to 100% and that he was getting the right fuel pressure?
Cheers,
-Tuan
Old Oct 3, 2005 | 09:18 PM
  #109
ThetunerFestNJ
Cheers,
-Tuan
It is a lower compression motor and upgraded fuel system.
Old Oct 4, 2005 | 12:34 AM
  #110
accordfreak's Avatar
accordfreak
subscribing.
thanks turboxs
Old Oct 4, 2005 | 07:21 AM
  #111
BlackTuner's Avatar
BlackTuner
Cheers,
-Tuan
Tuan,
At the moment I am questioning FPR or the Fuel Pump. We calculated that we should be able to supply enough fuel at this hp level. We are seeing 100% IDC's about 6000rpm. The car from there will just lean out uncontrollably to 12.6-12.8 afr. I will probably play with the car a bit tomorrow to see what's going on with the Fuel.
As this was on the 7th day of a work week. It was time to throw in the towel.
Thanks,
P.S. I had intentions on contacting you guys to run a prototype unit. Hit me up when you get a chance.
Old Oct 4, 2005 | 07:33 AM
  #112
ThetunerFestNJ
Doesnt APS reccomend 58 psi of fuel pressure at idle?
Old Oct 4, 2005 | 07:55 AM
  #113
failsafe306's Avatar
failsafe306
Jermaine, you have email.
Old Oct 4, 2005 | 10:30 AM
  #114
zero2prove's Avatar
zero2prove
Tuan,
Thanks,
Jermaine,
I ran into the same problem with a Z a couple of weeks ago, at 5800 RPM's the car was running lean no matter what I did with the unichip. We checked over everything with the fueling system, except for fuel volume. I did notice some similar behaviour with a car that Phunk brought to the shop as well. Both car's I believe were 03' models with a technosquare reflash. At this point I am suspecting that the reflash was cutting fuel out to early. I'm going to be getting that same car back for guages and then sending it to the dealer to reflash back to the stock programming to see if that will make a difference. I was only able to make 490whp on the dynapack with that car at 10-11psi with the fueling issue. Does that car you are tuning have a reflashed ecu? Just curious. I'll hit you with an email later.
Best regards,
Tuan Nguyen
www.grdperformance.com
Old Oct 6, 2005 | 04:53 PM
  #115
ThetunerFestNJ
the car has since been outfitted with 650cc injectors and tuning will begin tomorwow morning.Excited to see what kind of #'s it gets on stock APS actuators.
Old Oct 7, 2005 | 09:44 AM
  #116
ThetunerFestNJ
Update, with the 650cc injectors we made the same 480 WHP with a much safer 11.3 a/f ratio flat across the board at 11.6 psi of boost.The next step is to upgrade the APS stock actuators to some 9-15 springs and retune the car for the higher boost.We feel at 13-14 psi we should see 525 whp on pump gas and stock heads! With some race gas we will see most likely high 500's maybee even a 600.Over the winter we are doing the heads and cams for better flow. We shall keep you updated as we go!
Old Oct 7, 2005 | 10:26 AM
  #117
D350Z10's Avatar
D350Z10
OOOOO sounds promising... might have to get that!
Old Oct 7, 2005 | 10:30 AM
  #118
Havok_RLS2's Avatar
Havok_RLS2
All this sounds wonderful and all but when is the unit on sale? Whan are the numbers you're getting for N/A?
Old Oct 10, 2005 | 03:48 PM
  #119
BlackTuner's Avatar
BlackTuner
This unit should be for sale this month. We are just finalizing software at the moment.
Naturally Aspirated results can be found here
Thanks,
Jermaine~
Old Oct 10, 2005 | 04:08 PM
  #120
phunk's Avatar
phunk
CJ Motorsports
Please PM me wholesale and/or pricing information. i have a customer with a built engine running the APS TT and we are about to change the actuators and toss the Unichip. I would like to explore the possibilities of using the UTEC on this car.
Thanks!
-Charles
