Stillen SC Installed
Old Jan 29, 2006 | 05:51 AM
  #101
mlg9770's Avatar
mlg9770
ZEnclosures
Originally Posted by Silo
What was your stock whp/trp? And can anyone supply a dyno plot including A/F for a stage 2 on a otherwise unmodified car? It would help to determine how far "off" this fuel curve is compared to the intended fueling.
I didn't have a chance to dyno this car prior to the install of the SC.
Old Mar 13, 2006 | 05:01 PM
  #102
TTRANK's Avatar
TTRANK
Has anyone installed the Gold Pulley on an 03/04?
Any of you Stage 4 guys have a red pulley you want to sell?
Old Mar 13, 2006 | 05:38 PM
  #103
g35twinturbo's Avatar
g35twinturbo
+1. Somone pm me if u have a red pulley for sale. I got the ca$h waiting.
Old Mar 14, 2006 | 12:00 AM
  #104
BlackSpec02's Avatar
BlackSpec02
+2, I would definitely buy one as well... I believe the red is the stage 3 for 03/04 and the gold is the stage 3 for 05+, I dont know what color the stage 4 is. I have read on here that somehow the gold pulley makes a bit more boost however.
Old Mar 14, 2006 | 12:37 PM
  #105
Dr.G's Avatar
Dr.G
red is for stage 3(03 models), gold is also for stage 3 (04 models), and silver is for stage 4: the silver must generate more boost since it is the smallest one regardless of what some say about running rich etc.....
physics states: smaller pulley = more boost.
Old Mar 14, 2006 | 12:42 PM
  #106
mc4life's Avatar
mc4life
siiiiiiiiiiiiiiiiiiiiiiiik
Old Mar 14, 2006 | 12:52 PM
  #107
350z_this's Avatar
350z_this
too damn cool.....
Old Apr 24, 2006 | 07:22 PM
  #108
bfan13's Avatar
bfan13
what will happen if a gold pulley is installed on an 03?
Old Apr 25, 2006 | 12:12 PM
  #109
Dr.G's Avatar
Dr.G
you might get a tiny bit more boost. i think the difference comes from the size of the crank pulley driving the SC pulley. If SC pulley smaller = more boost, also if crank pulley bigger = more boost
Old Apr 25, 2006 | 12:47 PM
  #110
bfan13's Avatar
bfan13
then i should really get a/f readings then right? because that means i could be running even more lean than most ppl with a stage 3 setup. I dont understand why there woudl be different stage3 pulleys for the different years, tehyre all the same engine arent they?
Old Apr 25, 2006 | 12:52 PM
  #111
cersoft's Avatar
cersoft
Not as such, they went from LEV to ULEV in '04 ... the valve timing is different, beyond that I'm not sure, but there is definately a difference ...
Colin
Old Apr 25, 2006 | 01:03 PM
  #112
nateg35's Avatar
nateg35
bryan...don't worry dude...the color is different (depends on year/ G/Z) but they're the same
Nate
Old Apr 25, 2006 | 01:05 PM
  #113
Dr.G's Avatar
Dr.G
Colin
red or gold is ok with the control box provided with the kit. Both pulleys are within the range of the ECU/Box . the smaller pulley will give more power. Only when you go to stage 4 you need a different box and a different injector.
Old Apr 25, 2006 | 03:01 PM
  #114
bfan13's Avatar
bfan13
Colin
i meant for the 5AT engine, they changed that too?
Old Apr 27, 2006 | 02:22 PM
  #115
wilric44's Avatar
wilric44
Default Please Post Numbers No Dynos
Been reading about the Stillen Stage 2, 3, and 4 but have yet to read or see and HP or Torque numbers. I am about to purchase the Stage 2 just want to know what I can expect for gains.
I already have High Flow cats and exhause from Stillen. Thinking about the Nismo or JWT cams. I was going to do the VRT package but will wait until i get a earlier model 6MT 350Z. Not completely sure about TT and 5AT.
Any Info appreciated, its better than starting another thread
Old Apr 27, 2006 | 10:24 PM
  #116
BlackSpec02
one member dyno'd 343 with stage 4... i cant think of any one who has numbers for stage 2... i have stage 2 right now and it pulls MUCH harder than stock... lots more torque and a much more usable powerband. Ive been meaning to get mine dyno'd but ive got a laundry list of things I need to do first.
stillen is great for a daily driver, it offers little more maintenance over stock and great reliability. I would love a turbo but bought my car with the charger on it for the price of a stock z. Its been about 12000 miles with no problems all Ive had to do is replace the belts one time and removed an idler pulley that I couldnt get to stop squeaking.
Old Apr 27, 2006 | 11:52 PM
  #117
wilric44's Avatar
wilric44
Thanks for the info, I am looking for those numbers around 350 for now. Did you change your cams. I read your signature just wondering if you used nismo or JWT cams. Stillen quotes 312 for the Stage 2, but I wonder how much of gain with addtional mods. thanks for the info. I do not think anyone knows what the stage 2 numbers are.
Old Apr 28, 2006 | 12:03 AM
  #118
BlackSpec02
I plan to dyno before I upgrade to the stage 4. All I have right now, performance wise, besides the supercharger kit is the JWT pop charger, which I recommend, and the stillen exhaust which I recommend as long as you dont mind a stock look... Ive been thinking about trading for an HKS but havent found anyone who wants to.
The stillen kit doesnt respond well to headers... in fact they lose power, and Im not sure about high flow cats, but I doubt they will help much. I would recommend the pop charger or stillen intake along with an exhuast to squeeze extra power out of this kit. Cams will make power but probably not a ton, not enough for me to justify the price tag and ripping into the engine. The best way to go for power is stage 4 but you are probably topped out around 350whp max.... realistically.
You dont need much in the way of gauges for the stillen kit either, but I would recommend at least a boost gauge... which I have yet to do, but want REALLY bad.
Old Apr 28, 2006 | 12:05 AM
  #119
Silo's Avatar
Silo
I will be be able to supply you with stock vs. stage 2 numbers soon. We have just installed the Stillen blower, waiting for an oil cooler to arrive and will dyno again once installtion is completed. We also have installed a PLX-500 unit to meter A/F and EGT.
Old Apr 28, 2006 | 12:09 AM
  #120
BlackSpec02
^ awesome, I cant wait to see that dyno! Do you have another thread going or do you intend to post here?
