Cooling Mist water injection....
Old Mar 26, 2006 | 03:43 PM
  #121
trefling's Avatar
trefling
Just got my kit installed and here is what came with it:
Variabe boost controller:You set the min. psi you want it to come on and the max psi where the pump maxes out.
Pump: look just like the ones we use for booster pumps on water filtration systems
Plastic hose: looks cheap but pretty tuff, just keep it away from really hot surfaces.
Check valves, cloged warning light/system.
I must say that www.coolingmist.com customer service is very friendly and informative. I'm looking forward to seeing how this all works out. I have not had a chance to really test it out because I'm waiting for a retune with some modifications.
BTW...on the Z you only need a single stage and the variable boost controller makes progressive spray increase a breeze.
Old Mar 26, 2006 | 03:58 PM
  #122
booger's Avatar
booger
Looking forward to seeing the out come .
Old Mar 26, 2006 | 05:21 PM
  #123
coolingmist's Avatar
coolingmist
Sexy, huh? Sorry I could not resist. BTW, we have all hose types available for those that like stainless/teflon or flame resistant synthetic.
Old Apr 8, 2006 | 12:29 PM
  #124
JoeDirtPharmD's Avatar
JoeDirtPharmD
Opinions on Coolingmist($299) v. Snow($399)? Both products look comparable; trying to figure out what the extra $100 thru Snow offers...
Old Apr 8, 2006 | 12:37 PM
  #125
coolingmist
I am Bias but I will answer your questions in a very practical way. You are comparing our boost switch based system to thier controller based system, thats the difference in price.
You should compare our $299.95 Deluxe Kit + tank to there $299.00 kit if you want to compare ables to apples. Look at what each kit includes and you will find your answer.
The $399.95 kit from snow performance is their controller kit. Compare those to our controller kits. Our controller kits range from $450-$599.00.
Our controller is the most advanced "progressive" style controller on the market. I'm sure you will want to reseach both to see what you like better, but make sure you research carefuly as there is no comparison interms of features, abilities and construction of the actual unit.
Old Apr 8, 2006 | 03:31 PM
  #126
mrtomcat's Avatar
mrtomcat
I went with Snow because they had a kit that gave me what I wanted not too complicated but still had all the features I needed and for a great price.
Coolingmist confused the heck out of me because there is too much to choose from and nothing specific enough to what I wanted, they also did not have a boost controlled controller at the time.
I finally got my kit installed by the way and it works awesome.
Old Apr 8, 2006 | 05:47 PM
  #127
JoeDirtPharmD
Does the kit that I see in the link below come with a standard size nozzle, or are nozzle extra and determined by your power output?
I assume the difference between a boost switch and a controller is "all-or-nothing" injection v. "variable by psi" injection?
Old Apr 8, 2006 | 05:51 PM
  #128
coolingmist
I dont know if you are talking to me, but I dont see any link. Our controller kit can change the flow with the hardware or software so there is no worry about injector size. You can dynamically change the flow. The regular boost kits we get the HP range and size the nozzle.
Our controller is capable of running off MAF, TPS , Boost or Boost and TPS or boost and MAF. With the controller you can vary flow based on boost or 0-5V input. Ours has a CPU, software program that datalogs and lets you change the variables.
Old Apr 8, 2006 | 06:27 PM
  #129
JoeDirtPharmD
Cause I'm a dumbass and forgot to post the link http://www.coolingmist.com/detailmain.aspx?pid=01250TBF
Old Apr 8, 2006 | 06:28 PM
  #130
coolingmist
we get you a nozzle based on the HP that you select with that one.
Old Apr 9, 2006 | 12:45 AM
  #131
JoeDirtPharmD
Thank you for the reply
Using WI, what can a typical user see in 'octane boost' using 50/50 methanol/water injection? Target octane level is 96 using 91 pump gas.
Doable?
Old May 20, 2006 | 09:19 PM
  #132
trefling's Avatar
trefling
Here is some feedback from the new coolingmist system. With supercharging (procharger) and UTEC plus 50/50 mix of water/meth there is almost no trace of detonation loged. This is great news! Water/Meth injection is such great engine insurance, it really does what is is intended to do. The boss at coolingmist has also been very cool in helping and advice
Our intake temp were dramatically lower and no knock, that's a great mod if you ask me
Old May 20, 2006 | 09:21 PM
  #133
trefling's Avatar
trefling
Very doable
Old May 20, 2006 | 09:23 PM
  #134
350zDCalb's Avatar
350zDCalb
builtZmotors
will be including this on my upcoming setup
-TODD
Old May 20, 2006 | 09:37 PM
  #135
dscheers's Avatar
dscheers
With how much boost ? Build or stock engine ?
Old May 21, 2006 | 07:19 PM
  #136
baileyrx's Avatar
baileyrx
just purchased a dual stage set-up from cooling mist on Ebay for 279 shipped.
It has 2 sprayes, 2 adjustable boost controllers, etc. I did not come with a tank but I'm going to install a large tank in my trunk. Hopefully I can install this before my car gets tuned!
I'll keep ya'all posted
Old May 22, 2006 | 08:33 AM
  #137
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Wow you got the killer deal on that!
Old May 22, 2006 | 10:11 AM
  #138
Gman2004's Avatar
Gman2004
look in the classifieds. I don't know if it is still available but bigbri had a 30 gal tank for sale.
Old May 22, 2006 | 10:12 AM
  #139
sentry65's Avatar
sentry65
the burninator
30 gallons!!!! lol that'd be bigger than the car!
hehe I know, 3 gallons
Old May 22, 2006 | 10:21 AM
  #140
Gman2004's Avatar
Gman2004
hehehe. It would have been funnier if I put 300 gallons.
Here's the link.
https://my350z.com/forum/showthread.php?t=174881
