Vortech S-Trim w/dyno
Old Dec 1, 2005 | 05:36 PM
kevinapex's Avatar
kevinapex
My cost from Vortech was $ 147.00 took about 3 weeks for them to do, Talk to a guy named Jamie in tech. Best 147 i've spent yet for HP gains!
Ryan, Keep us informed on the 2.87" swap I've though a lot about that!
Old Dec 1, 2005 | 06:39 PM
QuadCam's Avatar
QuadCam
has anyone tried swapping the cogged pullies instaed of the 6 rib pulley?
If you stayed with the larger 3.33"pulley and then you switched out the cogged pullies, you wouldn't run into as many belt slippage problems...maybe.
Old Dec 1, 2005 | 07:10 PM
booger's Avatar
booger
I switched cog pulleys..I had a custon 34 tooth [ instead of the stock 32 tooth ] made for me . Im running the 3.12 serp pulley
Old Dec 1, 2005 | 07:46 PM
QuadCam's Avatar
QuadCam
I think auto specialties makes a 34 tooth cog for vortech applications already.
Old Dec 2, 2005 | 04:28 AM
booger's Avatar
booger
I got mine from Vortech . It was about twice as wide as needed . I had it cut and milled to fit . I think it was for Vett kit
Old Jan 30, 2006 | 04:54 PM
OldManZ350's Avatar
OldManZ350
Anybody upgrade there Vortech Blower Trim, still on stock internals ?
Old Jan 30, 2006 | 05:20 PM
booger's Avatar
booger
The shop got my motor back in and running good . SGP did a great job on the motor . They dropped the compression to 8.5 to 1 with CP piston this time . This is going to be one stout motor . It feels stronger even with the lower compression . Didnt feel any loss from it . I only went to 1/4 throttle to about 4000rpm's was running pretty lean and I saw 4psi so I didnt try to throttle it up any further . Im glad I didnt because the blower started to whine real bad . We checked the oil feed and return lines and they are fine . So the blower is going back to Vortech . The SGP valve body shifted great and is going to help alot . The 31+12+4 intercooler and 3in. pipe to the TB is going to help air flow a great deal . Cant wait to see what she will do . Now if Vortech holds to thier said 7 to 10 day turn around [ lol ..took a month last time ] it shouldnt be much longer
Old Jan 30, 2006 | 07:53 PM
acg's Avatar
acg
NIce to hear you got it almost worked out, I have almost the same setup as you except maybe you have a few things you maybe keeping secretive
350Z_Al
Oct 29, 2020 07:44 PM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
