Turbonetics 440cc Injector Replacment
Old Nov 5, 2005 | 09:03 AM
JETPILOT's Avatar
JETPILOT
Default Turbonetics 440cc Injector Replacment
Can I use the 440cc injectors with the stock TN kit with reflashed ECU?
Respect
JET
Old Nov 5, 2005 | 09:23 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
not without another reflash, or something to tune it with.
Old Nov 5, 2005 | 09:36 AM
JETPILOT's Avatar
JETPILOT
Thanks....
Respect
JET
Old Nov 5, 2005 | 04:40 PM
DBZ33's Avatar
DBZ33
If you need 440cc injectors you have probaly are at or over 400 RWHP. I would say you also need a fuel return system as well. They can flash your ecu to make them work. But I could be wrong.
Old Nov 5, 2005 | 05:32 PM
JETPILOT's Avatar
JETPILOT
I was just wondering if I could install the 440 injectors in place of the 380 injectors included in the kit and run the stock kit with 440 injectors instead of having to install another set of injectors at the time i'm ready for tuning and increased power.
Respect
JET
Old Nov 5, 2005 | 05:34 PM
JETPILOT's Avatar
JETPILOT
Will TN reflash my ecu for 440 injectors when I send them the ECU if requested?
Respect
JET
Old Nov 5, 2005 | 07:11 PM
Peking's Avatar
Peking
Respect
JET
I don't think so, you would have to use someone like Technospuare (who helped design the TN flash for the kit)... I sent mine off to them like four times to try to help fix my initial rich problem. Which ended up not working like I was hoping.
But honestly it can be rough (cause they don't have your car, they are basically tuning from a A/F graph), and expensive shipping the ECU overnight over and over again (depends I guess on how it takes to get it right).
Old Nov 5, 2005 | 07:51 PM
westpak's Avatar
westpak
SFZCC
I guess you could get the Greddy TT flash TS has.
Old Nov 6, 2005 | 08:21 AM
MIAPLAYA's Avatar
MIAPLAYA
Technosquare could flash for the 440s if you wanted...But if you plan to install a fuel return system later you could just hold off on the injectors. They are fairly easy to pull and replace.
Rev_Night
Nov 7, 2020 06:00 PM
350z82
Oct 1, 2015 06:25 PM
