Why Overheating now?
Old Dec 11, 2005 | 05:48 PM
paikman's Avatar
paikman
Sharif, was u bottom driver side hose warm at all during the initial one?
My top rad hosei s hot..but my drivers side doesnt get warm at all.. I dumped the fluids twice, refilling it the 3rd time with the valve open and still no luck
my car has 4000 miles.
Old Dec 11, 2005 | 05:53 PM
MIAPLAYA's Avatar
MIAPLAYA
You are saying the lower radiator hose on the drivers side is not hot? If thats so its your thermostat. The lower hose is the feed hose from the radiator to the motor. The Thermostat is not opening so water is not flowing through that hose.. Pull your thermostat and drop it in a boiling water pan. It probably aint gonna move. If you live in warm climates pull the thermostat off the housing and re-install the housing. Stock thermostats are junk. If not go get another sotkc thermostat for like $15 (the Nismo isnt worth another $100 just for a 20 degree opening diffference). But be prepared to replace it again.
Old Dec 11, 2005 | 07:19 PM
BLN350Z's Avatar
BLN350Z
Thx Sharif, Gonna play with it some more tomorrow!
Old Dec 12, 2005 | 06:17 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
THe driver side hose will not get warm until the thermostat opens, as MIAPLAYA alluded to. You need to free rev your engine, and get it nice and warm. Patience, my friend.....alas...you are getting closer.
There is no way to avoid this issue. You just need to take the time to properly bleed and purge the system of bubbles. Some shops have a vaccuum assist device, that makes the job much faster.
bneumann
Oct 7, 2015 12:16 PM
Poptarts
May 1, 2008 01:50 PM
joshp214
Jun 5, 2006 09:40 AM
Gman2004
Oct 26, 2005 05:22 PM
