[B]AT5 transmission Will not hold 400+ hp
Old Dec 28, 2005 | 09:55 PM
weslutes's Avatar
weslutes
This thread should have been labeled:
AT5 transmission Will not hold 478+WHP reliably
Also, think of how many times they ran it on the dyno to get that 500+ whp. They definately weren't babying it to get those numbers.
Hey, & remember when they put the VPRO in & tuned it. They said it was slipping like crazy at 330. You know.. Maybe you had a weak/faulty tranny to begin with. All of those runs they did with it slipping probably wore it out back then & now it took a **** after hitting that 538whp.
I know you'll fugure it out & fix it ASAP, so good luck.
Don't be so bummed, my car almost burned down on Christmas & now I have a new issue.
Wes
Old Dec 29, 2005 | 06:14 AM
roncfpz's Avatar
roncfpz
Originally Posted by GurgenPB
I don't know where you guys are comign from.... before my VB, I collected at least 12000 miles on near 400rwhp... And at least 2000 of those where on 420-440 rwhp on a STOCK tranny. We are about to do a build on that tranny, but i certainly do nOT feel the clutchpacks slipping.
Not true at all. The VB does NOT just make the tranny shift faster, it increases the clmaping force at WOP from 210psi of hydraulic pressure (approximately 3000lbs of clapming pressure) to 275psi (do the math on the clamping pressure) for a 31% increase in holding power. Remember that that tranny was designed with about 400crank hp (if oyu take into accoung that it's also found in the qx56). 30% on top of that should make it hold at east 533crank hp. Upgrading the TC and lowering it's stall should lower the fluid temps, which will probably increase it's holding a little bit (maybe negligible). Upgrading the cluth material and bands will get you only another 10% or so (from my research). Adding an additional clutch into each clutch pack, if that's possible here, will yield another 10-25%,a ssuming you go from 4 to 5 packs in that gear. By my calcs, you can then theoritically (and practically) get 630-720 crank HP, that's 510-583 whp reliably, assuming you have a fully and properly built tranny. If it's just the VB, then you are looking at 431whp minimum. All calcs assume 19% drivetrain loss. If you must push more power through the tranny relative to the amt of calculated horsepower that it can handle, then the quality of your ATF cooling IMO will play a major role in determining the ATs lifespan.
BTW, one can ask "why can't we crank the line pressure beyond the 275psi to get more clamping power?" The answer: you can, but that will overdrive the ATs hydraulic pump, and unduely affect its lifespan. With numbers beyond 275, it is estimated that the pump will last around 10-15K miles, and I belive this estimate assumes hard use. If that's what oyu are willing to do, that can sure be arranged.
Gurgen.....thanks! That is excellent info. You seem to be at the forefront of this journey into high HP for the 5AT. We're all learning with some of us testing the limits and some being more cautious. So far my tranny has about 2k miles on 402whp and feels fine.
Thanks,
Ron
Old Dec 29, 2005 | 06:26 AM
roncfpz's Avatar
roncfpz
Originally Posted by tinman
i had the built tranny on the car for about 5 months now.4 months on 402hp and 1 month on 452hp.it shifts hard and fast compare to stock.the reason i went with built tranny is to withstand the amount of HP i'm gonna push.straight from the guy who actually built it "this is good for 1000HP no problem" only time can tell.
Thanks tinman. I assume your rev limiter was raised and, if so, to what rpms? Also, can you describe the shifts at WOT in 1 and 2nd gear in full auto mode? Thanks again for your help.
Ron
Old Dec 29, 2005 | 09:53 AM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Thanks,
Ron
Glad I could help. I should have some more juicy information on this in the next 3-4 weeks. Stand by.
Old Dec 29, 2005 | 11:30 AM
tinman's Avatar
tinman
no problem.yes it was raised to 7100.
WOT in 1st & 2nd? BAM,BAM
Old Dec 29, 2005 | 04:37 PM
KPierson's Avatar
KPierson
If anyone is interested I have a used 5at for sale. It has roughly 7500 miles on it. It has been sitting in my garage taking of space for over a year now, as I have a 6mt. I bought it and a longblock in a package, and the guy wouldn't separate them.
Old Dec 29, 2005 | 07:16 PM
SungNamZ's Avatar
SungNamZ
Sent you a PM on the 5AT.
Old Dec 29, 2005 | 07:42 PM
CESAROTORRES's Avatar
CESAROTORRES
Default Good information
Subscribing
Cesar
Old Jan 9, 2006 | 05:17 PM
Aeleven's Avatar
Aeleven
what were the total mods to your 5AT, and who did the work?
Old Jan 10, 2006 | 04:49 AM
tinman's Avatar
tinman
there're few other mods,visit my webpage www.Tinmanpage.com or pick up a copy of www.Dragsport.com my car is in there.
www.Speedforceracing.comdid most of the works.
Old Jan 10, 2006 | 05:38 AM
roncfpz's Avatar
roncfpz
Tinman.....very impressive car and build. Looking forward (still) to getting my subscription copy of Dragsport in the mail soon and checking out your ride.
Ron
Old Jan 10, 2006 | 07:39 AM
tinman's Avatar
tinman
Thx Ron
already available everywhere here in Socal,let me know if you have problem getting one.
Steve
Old Jan 10, 2006 | 01:22 PM
MOTOP's Avatar
MOTOP
Gurgen,
We fried first set of clutchpacks on mere 0.5 Bar from Greddy TT after only 700 miles on the car, mind you that is with huge tranny cooler. My point is when it comes to FI on our auto trannies, there's no set number past which clutchpacks will start failing. It all depends on how you drive it.
Good luck with your tranny build. Our path is 6MT swap, all parts are sourced except for ECU, waiting on Technosquare.
P.S. Level 10 - is a big NO NO !!!
Old Jan 10, 2006 | 01:33 PM
roncfpz's Avatar
roncfpz
Originally Posted by MOTOP
Gurgen,
If you don't mind my asking, what is your estimated cost of doing the 6MT swap? PM if better.
Thanks!
Ron
Old Jan 10, 2006 | 01:40 PM
MOTOP's Avatar
MOTOP
It depends, labor being a huge factor.
Here's the rough list of what you will need hardware wise:
-6MT itself
-6MT interior stuff (gauge cluster, tranny tunnel cover, etc)
-6MT handbrake (not quite sure about that one yet)
-6MT pedal cluster
-6MT ECU
-6MT driveshaft
-6MT rear pumpkin (optional)
Once we're done with the swap (~2 months) I'm going to post a big write-up which hopefully will become a sticky.
Old Jan 10, 2006 | 01:50 PM
MOTOP's Avatar
MOTOP
Originally Posted by Fairlady_z33
Ive heard that the were bad at that one some guy a couple of months ago posted something about his tranny that he did with level 10 and that it sucked. One thing did you beat up on it after you got the 1k mile mark. I think the only way this is going to be resolved is when the clutch packs come out. Did they give you warranty on the tranny.
I was that guy and original post can be found here:
https://my350z.com/forum/forced-induction/129381-got-screwed-by-level10.html
Just putting it out there in case somebody is entertaining thoughts about using Level 10.
Old Jan 10, 2006 | 02:06 PM
roncfpz's Avatar
roncfpz
Thanks! Look forward to your write-up. Good luck!!
Old Jan 10, 2006 | 02:11 PM
  #38
vq35carel's Avatar
vq35carel
Its a different drive shaft
I estimate the cost of the conversion being around 6k+
07ZEKE
Aug 23, 2021 09:15 PM
burglapfd
Dec 6, 2020 01:04 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
