Emanage blue for turbonetics?
I have the emanage blue that I had on a previous car. I want to use it with my Z. I have the tnetics kit, hks custom 3' exhaust and motordyne 5/16 spacer. Is the emanage blue worth installing? Will I see some power gains? I will have it tuned at a shop with a dyno. Any input will help a lot.
You will see some power gains I highly suggest the Ultimate over the blue if you are looking to spend the extra money, but yes if you use the blue and get a custom tune you will see more power out of the car.
I would go with ultimate but I really dont have 500+ dollars right now. I need to have some parts on my car painted and that right there takes up the ultimate money. I have the blue already and harnesses so I figured why not? But I spoke to shariff and he was telling me that with the blue its harder to tune because you cant see what your doing. Something about I will have to take away fuel instead of add more. Im a newbie at this so Im still learning as I go by. The guy that will tune my car said it should work fine. I guess we will see.
My friend has had alot of problem with the emanage blue, I would rather wait that throw that on my car. even if it was free to me i wouldnt put it on, just not safe in my opionion ( rpm spikes, and other things )
You should be fine at mild boost levels, and with a good tuner. You do have to tune it a little bit more conservatively, since you cannot see actual timing with the Blue..only with the EU.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
