After TT setup....what do you do to generate further power?
Old Jan 8, 2006 | 11:42 PM
Roadstar's Avatar
Roadstar
Default After TT setup....what do you do to generate further power?
as titled..
after you install the TT and get it done right, what post modifications do you guys do to make your car push even more power?
do you guys swap the turbochargers with bigger ones? or you turn up the boost with your engine built? ?
wat do you guys dO
XBS's Avatar
XBS
Veteran
Lol
Old Jan 9, 2006 | 12:15 AM
punish_her's Avatar
punish_her
Originally Posted by Roadstar
as titled..
wat do you guys dO
That would be yes, and yes.
There are all sorts of things people do. the key is more cool air into the combustion chamber with more fule. So there is almost infinate things. Larger exhaust helps the flow of spent gasses, more bost for more air, upgrade the injectors, inline 2nd fuel pump, upgraded primary fuel pump, so on and so on. Also reducing rotational mass. well that doesnt make power it just frees up power that would be used to rotate the extra weight and transfer it through the drive line.
The 3 key factors though are: more fuel, more air, and less mass.
This is a simple and vague answer that boils down to money, you got the money, you can have the power.
I suggest, though; reading through a little more and see the big picture of the proformance forums. But don;t hesitate to ask if you cant find the info your looking for. Most people are more than happy to point you in the right direction. Others, well if it isnt info thats brand spanking new, makes free power or directly pertains to them; get pi$$ed when you ask genral and vague questions like "how do you get more power?"
Keep on trucking though. You too will become smarter.
Hawaii Mike
Old Jan 9, 2006 | 12:34 AM
JETPILOT's Avatar
JETPILOT
How much power are you talking about?
Respect
JET
Old Jan 9, 2006 | 01:26 AM
Roadstar's Avatar
Roadstar
Hawaii Mike
thnx bud, exactly wat im looking for~
Old Jan 9, 2006 | 03:31 AM
Zilvia's Avatar
Zilvia
build it and boost it
Old Jan 9, 2006 | 05:40 AM
MoodDude's Avatar
MoodDude
More Boost = More power = More likely to blow the engine
Be carefull when looking to add more power.
Safe power can come from getting rid of spent power. The easiest thing that will yield the most benefits for hp and cornering is to lighten up the wheels/tires combo. And you can do this yourself (how much easier can it be to change a tire?).
loudtoyz
Apr 6, 2023 04:52 AM
sales@czp
Sep 23, 2019 03:30 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
codek
Sep 28, 2015 03:03 AM
