Tomei 268 cams on FI car, who is using them?
Old Feb 18, 2006 | 12:11 PM
XBS's Avatar
XBS
Veteran
Default Tomei 268 cams on FI car, who is using them?
Just wondering who out there is using the Tomei 268 cams, and how do you like them? Big power increase at 15psi?, How does it idle? etc. Looking for input on diffrent cams as I am undecided what I should go with. Thanks!
-George
Old Feb 18, 2006 | 12:44 PM
mjedens's Avatar
mjedens
Default Tomei 268 Cams
I've had them for a couple years now (N/A) but went with a Greddy TT recently. Idle wasn't a problem as long as you had the idle @ around 900 rpms. When I went TT I also switched from the eManage to the HKS FCON so you might want to talk to a tuner on the tuning setup at idle. (SGP tuned mine) My low boost setting is at 17 psi and both rwhp & torque are in the mid 700's. I'm partial of course, but the lope of the cams @ idle (new exhaust last week) is impressive.
Old Feb 18, 2006 | 01:32 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Its a great cam, and definately on the aggresive side. Most engines wont idle without an ECU idle bump to 900-1000rpm, as Mike just mentioned. Otherwise, I like them for the 600whp+ crowd.
Trying to get a cam comparison going is nearly impossible. There are just way to many variables. The only thing people can compare are the idle quality, and possibly part throttle response.
Old Feb 18, 2006 | 01:40 PM
XBS's Avatar
XBS
Veteran
Would it benefit a high 500's low 600s whp car? I guess it will leave room for future power upgrades with out needing to replace cams again. I am just trying to do it once and do it right. I also like the aggresive cam sounds at idle with the idle jumping alot. Thanks for the input guys.
-George
Old Feb 18, 2006 | 02:08 PM
Sharif@Forged
Forged Performance
-George
Yes it will, I am just throwing up my ballpark thoughts on it. Higher duration cams will push the power curve to the right, so you will trade a little more bottom end trq/power, for more trq/power up top. You will also want to upgrade your valvetrain, to take advantage of an 7500-8000rpm redline, in order to maximize the benifits that higher duration cams will give you.
Old Feb 19, 2006 | 11:12 PM
XBS's Avatar
XBS
Veteran
I am going to be upgrading the Valvetrain, Just undecided on what cams to go with, will be revving the motor to 8K, So these cams would def. Benefit me in the 4-8k RPM range. ( even thought i dont want to take it to 8K to much, just 7.5K or so )
Old Feb 20, 2006 | 10:42 AM
DSport G35's Avatar
DSport G35
I have the 268's on the stock ECU and they idle fine, around 7-800rpms, if i keep the heater on. I have full Ferrea valve-train as well. When i'm driving if i put it in neutral from 3000rpms and above it will fall all the way down and die half of the time. So i just have to keep it in gear when coming to a stop all the way down to 8-1000rpms so it doesn't die.
Derek,
DSport
Old Feb 20, 2006 | 03:44 PM
IceY2K1Max's Avatar
IceY2K1Max
That's what the Nismo VTC pulleys are supposed to help, however without the ability to control VTC timing, it doesn't help.
Someone needs to figure out a solution to the VTC pulleys.
Old Feb 20, 2006 | 03:55 PM
DomZ's Avatar
DomZ
But what cam grind would work better with our current RPM range? Just a question for those who don't want to necessarily rev that high...
Old Feb 20, 2006 | 04:48 PM
Sharif@Forged
Forged Performance
Derek,
DSport
So it's not idling just fine. We usually bump up the idles to 1000rpm, so the idle is rock solid, and the engine never dies.
Hey Derek, any updates on the car? You should start another thread...I am sure many people would like to know your progress.
Old Feb 21, 2006 | 12:50 AM
DSport G35's Avatar
DSport G35
Hey Sharif...Haha, yeah i guess they dont idle "fine" but more like "it runs". Getting the exhaust done this weekend by Speed Force Racing so i'll get some udated and a new thread up next week.
Derek,
DSport
Old Feb 21, 2006 | 06:13 AM
Sharif@Forged
Forged Performance
Derek,
DSport
Noice!
pslamp32
Feb 8, 2017 09:07 AM
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
RyansZ33
Sep 15, 2015 05:54 AM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
