RPM signal?
Originally Posted by SungNamZ
ECU Connector: Terminal #62, RPM Signal - Ignition Coil Cyl #1 (RPM) Wire Color: Yellow/Red
Tx
Ken
Originally Posted by Sharif@Forged
What device are you tapping this RPM signal to?
Is there a aftermarket sendor that could be installed to get a RPM signal? It wouldn't matter is it's a dc voltage that is RPM dependent or a pulse output.
I'm making a device that, among other things, needs to know the RPM.
Tx
Ken
Originally Posted by ken350z
Glad you asked because I'm not crazy about modifying the stock wiring at all. Even just stripping it back and tying another wire to is less than ideal. Also that signal going to thet ECU has a very small voltage signal. It must be the voltage drop across diode in the rpm sensor where the real information is the current rather than the voltage.
Greddy makes some sort of RPM box that taps all six injectors and combines the signal in to one 6 pulse per revolution signal.
I have used the crank angle signal (as well as an injector signal) wire with great success with my KPtechnologies shift light.
Originally Posted by KPierson
The injector signal comes FROM the ECU, it doesn't go to it.
The injector signal comes FROM the ECU, it doesn't go to it. The signal in questions (injector #1 is a 0 - 12vdc frequency based signal, it doesn't have any current component to it. This signal triggers the coil to fire.
Does anybody think that if I planned for pulses from something like 1v to 15v that it would work for most cars?
Tx
Tx
Ken
Tx
Ken
You're right, of course, don't know what I was thinking.
Have you looked at that signal with a scope? I haven't but the low resolution pic in the manual looks to be about 3 volts peak. It took a while to find what the silly star meant but I gues it's an average for measuring the signal with a voltmeter.
Tx
Tx
1 to 15vdc would be a good start, and I would suggest heavy filtering on the input. There are some cars with some really noisy signals that are very hard to work with. I don't think I would go all the way down to 1vdc on the low end though, I would want a slightly higher switching reference to help filter out some of the switching noise.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
etkms
Jun 19, 2022 06:30 PM
Justin100
Nov 29, 2015 03:58 PM
hardwood66
Sep 8, 2015 04:31 AM
