Danger in running without SC hooked up?
Old Feb 19, 2006 | 01:06 PM
dixieland's Avatar
dixieland
Default Danger in running without SC hooked up?
Quick questions guys - i am having some horrible rumbling out of my Vortech Supercharger blower that is not being fixed by my adjusting any of the belts or pulleys. Until i get a definate answer from Vortech or diagnosis the problem, is there any danger in running the vehicle without the supercharger hooked up? In other words, if i remove the gilmer belt, and tension pulley so that the SC is not doing anything, am i hurting anything by driving the vehicle. I have to go on a long trip by the end of the week (700-800) miles and don't want to run it if i am hurting the car. Will my fuel injection be effected or will it adjust to not having the forced induction? I think i have seen on here that someone will run their car NA until they get a belt replaced on the SC system - is this ok? Thanks
Old Feb 19, 2006 | 01:26 PM
booger's Avatar
booger
No problems . I would un do the IC pipe , the one thats goes down behind the blower . Turn it out towards the fender and put a piece of foam filter over the end of the pipe . SO the car can breath much better . Might want to reset the ECU also
Old Feb 19, 2006 | 01:29 PM
dixieland's Avatar
dixieland
ECU? Sorry not that knowledgeable yet! What is the ECU? and how and to what would i adjust it?
Old Feb 19, 2006 | 01:32 PM
booger's Avatar
booger
its the cars computer . disconnect the battery for 12 hour...easiest way . but getting it to breath better would be more important
Old Feb 19, 2006 | 08:33 PM
Gman2004's Avatar
Gman2004
If the noise your talking about sounds like rocks in a blender at low idle it seems to be pretty common. when I had the vortech I had the same sound. It would go away when I turned on my a/c and my idle went up to 800 rpms.
check out this thread.
https://my350z.com/forum/showthread....ghlight=rattle
apex locator
Jul 23, 2021 02:27 AM
350z82
Oct 1, 2015 06:25 PM
