Vortech Owners - Bypass Valve Change
Old Feb 20, 2006 | 08:36 AM
Hollywoodfraser's Avatar
Hollywoodfraser
Default Vortech Owners - Bypass Valve Change
Has anyone replaced the bypass valve that comes with the Vortech kit with another bypass/blowoff valve?
Results? Comments?
Old Feb 20, 2006 | 08:42 AM
k3silk's Avatar
k3silk
not sure but i thing the greddy type s will fit?
Old Feb 20, 2006 | 10:24 AM
SungNamZ's Avatar
SungNamZ
I tried the Greddy Type - S! It fits, but didn't like the release sound (i.e. sequential flutter), so went went back to the Vortech BOV.
Old Feb 20, 2006 | 06:34 PM
kevinapex's Avatar
kevinapex
I also tried Greddy type -S I went back to Vortechs as well. Still have the Greddy S in the box! Don't know what to do with it?
Old Feb 24, 2006 | 01:32 PM
Hollywoodfraser
Has anyone changed over to the Greddy/HKS and had problems? It is my understanding that the Vortech has more of a bypass valve which more or less acts like a closed loop.
With a BOV, the air is vented to atmosphere. Will the MAF misread information causing problems (hesitation? running rich?)
Are the Vortech and Greddy interchangeable?
Old Feb 24, 2006 | 02:44 PM
booger's Avatar
booger
The Greddy S type and RS type are BOV's and not Bypass valves . Work different . I couldnt get the either Greddy's to work . The Bypass valve on the Vortech was designed to vent when not in boost and close when vacuum drops and PSI starts to build . The vacuum closes the valve and the boost helps it stay close till the TB closes . Then vacuum builds and it open back up to vent off the boost built up in front of the TB . The BOV works in the other way . Its closed under vacuum and vents when boost builds to adjusted level . So when the TB closes the boost builds in front of it and opens the BOV only long enough to vent the boost at the adjusted level
Old Feb 24, 2006 | 06:46 PM
dimebagdolf's Avatar
dimebagdolf
Rob at Z Car Garage in San Jose, CA did mine.
He's got some sort of silencer he created and it works great. Super quiet.
Hit them up for details.
www.zcargarage.com
Old Feb 24, 2006 | 07:29 PM
acg's Avatar
acg
He did mine also, I can hardly hear it now.
Old Feb 25, 2006 | 04:27 AM
Hollywoodfraser
I am not looking to silence the sound of the Bypass/BOV. I'm acutally trying to get a louder sound (the typical BOV 'voosh' sound) which is not evident with the Vortech one.
Old Feb 25, 2006 | 07:03 AM
chimmike's Avatar
chimmike
try the forge diverter valve ( 007)
www.forgemotorsport.com
Old Feb 25, 2006 | 02:14 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
If you want it louder simply turn the bypass valve so the opening is pointing out to the side instead of towrd the middle. You'll be happy and it's easy to do. That's how I have mine and everybody can hear it.
Old Feb 26, 2006 | 10:25 AM
freezeg35's Avatar
freezeg35
got any pics of this?
lapham3
Oct 7, 2022 03:15 PM
kyin
Oct 15, 2015 05:54 AM
