My dyno sheets before and after UTEC.
Old Mar 15, 2006 | 04:40 PM
craigo'sznprgrs's Avatar
craigo'sznprgrs
Exclamation My dyno sheets before and after UTEC.
Guys,
Just to clarify, there had been some hot and bothered members convinced at 6.67 psi that 400.8 whp would be flywheel, but this graph should rectify that situation, hopefully.
Turbonetics reflash with exhaust, spacer, and no utec. The ultra low numbers are where BATLGROUND TUNING screwed my car up royally , the highest number was the first run: Yes, I strongly advise anyone in the Atlanta area to avoid this company at all costs, Knowledge is about 13 miles north of them, go there!!!
This is where I took it to Knowledge Performance in Kennesaw. The yellow is also on the Turbonetics reflash, first you will notice an actual decrease from the above graph, evidently the dynapacks read lower?
Finally here is the boost graph:
Old Mar 15, 2006 | 04:45 PM
TTRANK's Avatar
TTRANK
No, dynapacks read high because they are not load or wheel sprung weight based.
Very nice numbers!
Old Mar 15, 2006 | 04:55 PM
craigo'sznprgrs
I thought so too, but the same tune netted lower numbers??? Who cares, I am very happy, lol.
Old Mar 15, 2006 | 04:56 PM
plumpzz's Avatar
plumpzz
nice, i was expecting a bigger difference in the mid range but maye ur tuner did a good job to begin with
Old Mar 15, 2006 | 05:36 PM
thawk408's Avatar
thawk408
The Dynojet number is the more accurate of the two. The DynoPack numbers are way to high for the psi you are running. Also, I might be missing something but your A/F is kinda funky. It goes from to rich to to lean. Looks kinda dangerous to me.
Old Mar 15, 2006 | 05:52 PM
craigo'sznprgrs
It was dangerous, that is why I got it tuned: My numbers with that exact same tune on the dynapack were lower. The dynapack numbers are with the tune. Man, you guys are rough. I post dynos and you still doubt them, lol. The first dyno is untuned, the second is tuned. The numbers in yellow are with the exact same tune as the dynojet run, EXACTLY. The dynapack read lower for the EXACT same tune. I don't mean to come across nasty, but it said that in the very beginning of the thread. I am still under the impression that this particular dynapack was reading lower, but I understand why the dynapack should read higher, no wheels are on the car, but the car is calibrated for load, otherwise whp couldn't be obtained, if I am wrong about this sorry, this is just my understanding.
Old Mar 15, 2006 | 06:14 PM
tig488's Avatar
tig488
i wouldnt say avoid batlground, they are one of the top tuners in the southeast. they were the first to do a RB swap in a 350z. they do excellent work, just because they didnt get the best numbers for your car doesnt mean you should put them down.
plus ive heard bad things about knowledge also, isnt that the shop that installed all of pekings stuff and messed some things up?
Old Mar 15, 2006 | 06:24 PM
craigo'sznprgrs
True, they have positive attributes with other tuning mediums, but I hate a company that will outright lie to a customer. I was informed without a doubt they have tuned and can tune a UTEC. They basically charged me a butt load of money to retard my timing 20 degrees statically, literally that is what the map showed. Nothing else was done, if I hadn't unplugged the UTEC, without a doubt I would have blown my motor eventually and according to Knowledge, sooner than later. After showing my mechanic, he also was disgusted. The reason I am most upset is instead of correcting or better yet, finishing my tune, they chose to allow an acura nsx use the dyno and honestly told the tuner to rush it without any regards to me or my vehicle (main reason I am pi$$ed off). They also kept my utec software (which I had to make another trip to get back), crammed the UTEC into position and all around I have had to replace and or fix many parts due to a very very poor install.
I have spoke to Peking and feel as though his situation did indeed suck, but every shop will eventually have a dissappointed customer, the good ones are ones that step up and attempt to rectify the situation. There is much more to the situation with Batlground than I have mentioned, mainly because I am trying to decide whether or not to take legal action against them!!!
Old Mar 15, 2006 | 06:45 PM
thawk408's Avatar
thawk408
Ahhhh, ok. Nevermind my post I was just confused as to what you posted. Your all good .
Old Mar 15, 2006 | 06:52 PM
Peking's Avatar
Peking
Agreed Battleground is a very popular place for work and dyno days.
And yes I had a bad experience with Knowledge, though like I stated my friends have not... Situation of course was different for them, but I agree with Craig... Everyone will have positive and negative reviews.
Oh and Craig's boost level still puzzles me
Old Mar 15, 2006 | 06:53 PM
backagain's Avatar
backagain
is it tuned now ? i thought a tuned afr should stay around 11.8 or atleast more consistant afr
Old Mar 16, 2006 | 06:26 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Is the 377whp run on the dynojet tuned? If so that sucks man, your A/F is all over the place. If its not tuned, then what are your new A/F's on the dynapack dyno's posted.
Old Mar 16, 2006 | 11:44 AM
craigo'sznprgrs
ON the dynapack rock solid 10.5:1 across the the board, I lost that sheet from the retune. Yea, the original reflash did a number teh car was detonating audibly, it was pretty bad, then Batlground got a hold of the car and quite nearly destroyed it.
Old Mar 16, 2006 | 01:12 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Wow 10.5 is kinda rich for a "tuned" car, but what do I know....
Old Mar 16, 2006 | 08:03 PM
Bullitproof's Avatar
Bullitproof
i was tuned for 10.9 on the top end for winter. better to be a little rich than too lean and go BOOM!!! for the summertime i'll probably get it remapped to 11.3-11.5.
Old Mar 16, 2006 | 08:23 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Hey your kinda close to me, we should have a ST battle
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
seagrasser
Oct 11, 2015 03:27 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
