Headlift -- sleeved and non-sleeved engines
Old Apr 17, 2006 | 07:43 AM
  #121
Gman2004's Avatar
Gman2004
Originally Posted by overZealous1
not sure how more hp is going to help you get away from the head lifting issue lol
It's not the horse power that is lifting the heads it's the boost pressure. So if I can make 600whp at 12psi vs 16psi I won't have headlift.
Old Apr 17, 2006 | 07:51 AM
  #122
theking's Avatar
theking
It's not the boost pressure, it's the cylinder pressure. I still have a hard time believing it's headlift and not vapor eating up the HG. If it were headlift you figure the guys on the stock motor with anything over 450whp would be blowing HG's since the stock motor has stretch bolts.
Old Apr 17, 2006 | 07:55 AM
  #123
Gman2004's Avatar
Gman2004
How do you stop vapor from eathing up a gaskit?
Old Apr 17, 2006 | 08:19 AM
  #124
overZealous1's Avatar
overZealous1
ya it is cylinder pressure that is doing it. i will find out where exactly it is leaking hopefully by the end of the week. it could be inbetween the cylinders that the head is flexing and letting the cylinder pressure past. if that is the case i have a fix for that. but that little trick isn't gunna be made known till my motor is back together!! hahah. we are still planning to o-ring the block with a thinner ss wire ring. if all this stuff does not work, i have no idea what will and we would have to hope on someone to make new block castings like they did for the hondas.
as said earlier, i'm going pretty much all out on it, so we will see.
Old Apr 26, 2006 | 05:17 AM
  #125
mjedens's Avatar
mjedens
For those wondering if a 30# pressure cap vs a 18# will keep the coolant from overflowing!! The answer is yes "but". The coolant now goes thru the "blown head gasket" into the oil. This happened with the boost controller off (no more than 10 PSI) while trying to put some miles on my new clutch! I really knew better than to try the above but I couldn't help myself.
Old Apr 26, 2006 | 06:21 AM
  #126
phunk's Avatar
phunk
CJ Motorsports
mike, it sounds to me like your sleeves might not holding their integrity. i do not believe it to be very likely that the coolant would make it to the oil drain-backs... but then again its still very possible. But the combustion pressure would seep from the cylinders to the water passages that surround it and evacuate into there. i do not believe that 30# of water pressure is going to push the water thru the headgaskets and allow it to get into the oil. but if your sleeves are not sealing to the block correctly, this would allow water to push past the sleeves and go straight into the crankcase at the base of the sleeves.
Old May 6, 2006 | 03:07 PM
  #127
mjedens's Avatar
mjedens
Charles, you were right! It looks like the Darton Sleeves are the culprit for the water in the oil. I'll try to post a couple pictures on Monday that show the failure. The cometic gaskets looked okay to me but I'm not an expert. I'll get some professional help on Monday. (Mechanical & "Mental")
Old May 6, 2006 | 03:09 PM
  #128
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Who installed the sleeves..>SGP or Darton?
Old May 6, 2006 | 03:30 PM
  #129
mjedens's Avatar
mjedens
Hey Sharif. Tried calling you today but couldn't catch you! I haven't got an answer from SGP yet so I don't know what my course of action will be. I wanted to fax you some pictures to get your opinion, will do it Monday.
Mike
Old May 6, 2006 | 03:53 PM
  #130
350zDCalb's Avatar
350zDCalb
builtZmotors
Mike
please tell...who installed these? when?
Old May 6, 2006 | 05:45 PM
  #131
meatbag's Avatar
meatbag
Any updates? I would like to know since my darton sleeves were done by SGP's machine shop as well.
This is the last thing i want to hear about, ive had so much trouble trying to get my car up and running that im about to quit on it.
Old May 7, 2006 | 02:29 AM
  #132
mjedens's Avatar
mjedens
I'm having a local machine shop look at it Monday. I should have waited until then to make the report. Please don't jump to conclusions like I have done!
Old May 7, 2006 | 11:56 AM
  #133
t32gzz's Avatar
t32gzz
Mike - I would love to see pics of the HG. Can you post them here? If not, pm me for my e-mail address.
Old May 7, 2006 | 12:22 PM
  #134
Sharif@Forged
Forged Performance
Hey Mike,
Based on our conversation, and your observations, I think its too soon to conclude that the sleeves were at fault. Once your machine shop confirms the deck, we'll have a better answer.
Old May 8, 2006 | 01:24 PM
  #135
meatbag's Avatar
meatbag
Any news yet? I got some needed reasurence about my block today so hopefully your sleeves havent sunk.
Old May 8, 2006 | 01:28 PM
  #136
Sharif@Forged
Forged Performance
I hope I am not eating my words, but the method of cutting the block, and installing the Darton sleeves makes it impossible for them to sink.
If sleeves are going to go bad, it would have happened during the intense dyno tuning that SGP conducted on the motor. You would have known there was a problem very very quickly.
Old May 9, 2006 | 12:52 AM
  #137
Trav4011's Avatar
Trav4011
Well, I'm assembling a FWD VQ for a drag Maxima.. we're using AEBS sleeves, Cometic gaskets, and the standard ARP studs. I, for one, am not convinced that the cylinder heads are flexing/distorting. If that were the case, you would see stress cracks over a period of time. JWT recently tuned one of VRT's cars to the tune of 800+whp... on stock head bolts and gaskets! The car was road raced at the 550whp level, and flogged on the dyno repeatedly... How did this engine not have head lift issues?
We're shooting for 800-850whp in our drag car... So, we'll see how it holds up.
Travis
Old May 9, 2006 | 05:44 AM
  #138
350zDCalb's Avatar
350zDCalb
builtZmotors
Travis
Because they aren't telling the whole story At these power levels, without sleeving the block and using larger studs-BOTH..you will have problems
Old May 9, 2006 | 05:48 AM
  #139
Gman2004's Avatar
Gman2004
I didn't see headlift on the dyno. It took repeated high boost freeway runs for me to see it and it didn't take a year for it to surface like others have reported. My motor was weeks old.
Old May 9, 2006 | 10:16 AM
  #140
royce so's Avatar
royce so
good luck with the car, but that thing will have no class to race in. none of the classes in the major s/c sanctioning bodies allow fwd 6cyl. cars.
Travis
