Headlift -- sleeved and non-sleeved engines
Old Feb 15, 2008 | 06:37 PM
  #161
G35cTT's Avatar
G35cTT
Originally Posted by George@GTM
How did you bleed the cooling system? +1 on what Sharif said, your probaly isn't properly purged of all the air. When you turn on the heater does it get hot right away, or does it take a while and not get as hot as it should (like when it was stock)
LMK,
-George
GT Motorsports
It does not get hot right away. But would it still do this after a week of driving? Been driving like this a little longer then a week. Or doesn't matter how many miles I drove?
Old Feb 15, 2008 | 06:39 PM
  #162
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
The air can be very stubborn....it's still in there.
Do you have a spill funnel or some other way of doing a thorough purging?
Like George said, the easiest way to check, is you should have VERY hot air coming from your vents once the car is up to operating temp.
Old Feb 15, 2008 | 06:41 PM
  #163
G35cTT's Avatar
G35cTT
I do have a funnel. What is the best way to get the air out?
Old Feb 16, 2008 | 11:12 AM
  #164
Sharif@Forged
Forged Performance
this is the best/safest/cleanest thing to use: http://www.monstermarketplace.com/Au...666a15625.html
Old Feb 16, 2008 | 11:38 AM
  #165
G35cTT's Avatar
G35cTT
I was about to get one of them, here's a cheaper price and thanks for the tips.
http://www.hechinger.com/web/catalog...tive%20Product
Old Feb 16, 2008 | 11:52 AM
  #166
G35cTT's Avatar
G35cTT
BTW w/ this funnel am I supposed to purge the air w/ the engine running?
Old Feb 16, 2008 | 11:58 AM
  #167
App6MT's Avatar
App6MT
Yes. You want to get the engine warm so that the coolant will cycle. The goal is that the water going through the block will push the air pockets out.
Old Feb 16, 2008 | 12:07 PM
  #168
G35cTT's Avatar
G35cTT
OK, do I need to have the heater hose air relief plug open as well? Thanks for the info guys!
Old Feb 16, 2008 | 12:30 PM
  #169
Sharif@Forged
Forged Performance
Nope...no need to open it. Just run the engine....rev it up....get it VERY hot.
Who did your install? You could have them do the purge if you aren't comfortable doing it yourself.
Old Feb 16, 2008 | 12:51 PM
  #170
G35cTT's Avatar
G35cTT
SFR did the install but I sort of want to do this myself so I can do it in the future w/o having to bring it in the shop
Old Feb 16, 2008 | 12:59 PM
  #171
G35cTT's Avatar
G35cTT
I saw on another thread they had to do this for 5 days straight to get the air out. Is that a normal thing?
Old Feb 16, 2008 | 01:46 PM
  #172
Sharif@Forged
Forged Performance
Only need to do it for about 30 mins or so.....not 5 days.
Old Feb 16, 2008 | 07:18 PM
  #173
G35cTT's Avatar
G35cTT
Hopefully this does the job, I'll try it when I get the new funnel. I know when I got it installed they didn't take 30 min to purge the system. Thanks for the info!
Old Feb 20, 2008 | 05:59 AM
  #174
gothchick's Avatar
gothchick
I recently installed a koyo. The way I purged the system after install was to:
1) Fill the new rad up until it was topped off.
2) Then I opened the breather hose near the firewall on the passenger side, and litterally poured coolent into it (about 1/2 gallon) until it was topped off.
3) Closed the rad & breather up
4) Started the car and let it go through a cooling cycle. verified hot air from the heater.
5) Drove it around. Everything was perfect. No fuss no muss.
Attached Thumbnails Headlift -- sleeved and non-sleeved engines-rad-purge.jpg
Old Feb 20, 2008 | 06:46 AM
  #175
Philthy's Avatar
Philthy
Boost Junkie
I'm not sure if it was mentioned already, but you may also want to try jacking the front of the car up - it'll speed up the process!
Old Feb 20, 2008 | 06:52 AM
  #176
merlin3's Avatar
merlin3
I did mine just like gothchick and had no problems at all.
Old Feb 20, 2008 | 09:38 AM
  #177
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
IF you have a turbo Z and you drive it hard.... You need to purge your motor often
Or
Bad things will happen!
Old Feb 20, 2008 | 09:55 AM
  #178
Quamen's Avatar
Quamen
I just fill the car up and let the coolant get hot. Then I turn it off and open the relief valve on the heater hose slowly until I hear air coming out. I do not remove it though. I let it sit there and relieve air until coolant starts to trickle out of the crack. Then I shut the relief valve.
I just do that as many times as needed for no air to come out on the intial opening of the valve, letting the engine cool down and topping off the coolant between each cycle. Never had issues with that method.
Old Feb 21, 2008 | 09:50 AM
  #179
G35cTT's Avatar
G35cTT
Or
How often do you have to purge your turbo Z? I haven't tried the technique Sharif suggested but as soon as I get my funnel I'm going to try it out. I've tried to do the other way opening the heater relief and everything is ok when cruising around but when I drive the car a little harder my car overheats.
Old Feb 27, 2008 | 06:36 PM
  #180
G35cTT's Avatar
G35cTT
I got my funnel and did as Sharif suggested but ran it for 35min and my car took in almost 2 bottles of coolant and half a bottle of distilled water. Haven't yet got to test out if it did work but that's alot of air in there if you ask me. I'll let you guys know how it goes, hope that takes care of over heating issue. Thanks for the information
