Quirky bump in Dyno Sheet...
Old Mar 21, 2006 | 06:28 PM
JoeDirtPharmD's Avatar
JoeDirtPharmD
Yes - running 91 MAP
Seems the DynoJets at Intense and AZDynoChip are different models, hence the likely difference in output #'s. Problem is, Intense moved and is closed to the public, and no dyno available at this time. I called 6 places in the PHX valley looking for a DynoJet; most everywhere I called said their dyno was not publically available. *shrug*
Old Mar 22, 2006 | 07:36 AM
dynamic6er's Avatar
dynamic6er
Originally Posted by JoeDirtPharmD
They did, but they recently moved, and are now closed to the public. AZDynoChip has a DynoJet - going there Friday morning to see if its an octane-related issue.
Motor is stock, plugs are NGK one-step-colder plugs and gapped at whatever the instructions were per APS install (0.035? I think...?)
Now that the ticking is gone and it purrs, going to load up on some 100 and run it on a DynoJet again, hoping to see if I have a different outcome. If it resolves the quirk, then I know I simply need to find a local source for octane > 91, or turn down the boost a bit...
How long have you been running them? How long did you run them with the APS out of the box tune?
user 62082028
Southern California
Jul 28, 2017 11:47 AM
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
seagrasser
Oct 11, 2015 03:27 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
