Oil pan spacer ????
Old Mar 24, 2006 | 03:33 PM
booger's Avatar
booger
Default Oil pan spacer ????
I have been having trouble with my blower [ loud whine ] and I want to check to make sure the shop installed the spacer for the oil pick up with my oil pan spacer . Im thinking if the pick up spacer isnt there and the oil pick up is sitting higher than it should , that it starving the motor and blower of oil when I get into the gas and oil is forced to the back of the pan .
How close to the bottom of the lower oil pan should the oil pick up be ?
I want to eliminate ever possible cause and this is just a shot in the dark , but I want to make sure
THANKS Bill
Old Mar 24, 2006 | 04:05 PM
Alberto's Avatar
Alberto
Cranky FI Owner
The pickup is less than 1.5" from the bottom of the pan Id say....
Old Mar 24, 2006 | 04:10 PM
booger's Avatar
booger
OK...so if the pick up spacer is in place . The pick up should be sitting about to the bottom of the upper pan or a little lower ...thanks
Old Mar 24, 2006 | 07:51 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Yes but the easiest way to tell is to look and see if there is a spacer sandwhiched between the pickup and the oil channel leading into the block(I dont know the name of this) but its self explanitory. I assume you'll be dropping the pan? Its a messy job, not hard just takes a little while removing all that gasket maker...and btw the pickup from what I recall sat close to the bottom of the lower pan.
Old Mar 25, 2006 | 04:26 AM
booger's Avatar
booger
I didnt know if you would be able to see it or not . I'll look for sure
Old Mar 25, 2006 | 07:10 PM
booger's Avatar
booger
Thanks Alberto...Was actually pretty easy . Spacer was in place and pan is back up . Permatex is curring over night before I put oil back in it
Old Mar 25, 2006 | 07:12 PM
Alberto's Avatar
Alberto
Cranky FI Owner
No problem glad you had an easy time with it, my $hit was caked everywhere...
Old Mar 26, 2006 | 04:28 AM
booger's Avatar
booger
The SHop used Permatex [ red stuff ] and it comes off pretty easy . Used the wire wheel on the bench grinder to take off what I could scrape off . It came off the spacer real easy
apex locator
Jul 23, 2021 02:27 AM
burglapfd
Dec 6, 2020 01:04 PM
