Quick GReddy TT kit question...
Old Apr 11, 2006 | 09:56 PM
Metal Heart's Avatar
Metal Heart
Default Quick GReddy TT kit question...
I plan on getting the GReddy kit shortly. Now I know it comes with E-manage Blue and (from what I understand) a pre-made tune for 6 psi, to run is "safely" as they put it. I plan on getting a Walbro 255lph Fuel pump right away with the kit as well, but I won't have the cash for the AAM return fuel system right away.
Would it be safe to leave the kit at the 6 psi with the E-manage Blue tune, and the Walbro installed for a few months ? I know it won't make much more than maybe 330whp, but thats fine with me. I'm just curious about the safety.
Thanks
Old Apr 12, 2006 | 04:49 AM
Gman2004's Avatar
Gman2004
t0 run it safely you need to buy the ignition harness which cost $45. You need this so you can retard the timing other wise you will be running the kit on the OEM timing. I would recommend you get the ignition harness and get the car custom tuned.
Old Apr 12, 2006 | 06:03 AM
westpak's Avatar
westpak
SFZCC
At stock boost the kit runs very rich so adding the walbro will just make it worse if you do not tune it.
Old Apr 12, 2006 | 06:06 AM
Metal Heart
Ok, so does it come with a tune already on it? Or not?
I don't mind getting it tuned. I just wanna know if it'll be safe as is with the walbro for a month or two.
Old Apr 12, 2006 | 06:09 AM
zz350zz's Avatar
zz350zz
Yes the stock kit does come with a tune however it will run the rich for safety precautions. The factory fuel pump can handle a stock greddy TT kit you don't really need the walbro unless you are looking for higher whp #'s
Old Apr 12, 2006 | 06:17 AM
Metal Heart
If that's the case, what can you run with a walbro and the e-manage blue and a proper tune? more than like 330whp?
Thanks
Old Apr 12, 2006 | 06:19 AM
theking's Avatar
theking
400whp+ with the ignition harness as well.
Thanks
Old Apr 12, 2006 | 06:21 AM
westpak's Avatar
westpak
SFZCC
Thanks
With walbro, emanage and a tune plus a timing solution (ignition harness or J&S Safeguard) you run around 8 psi and arounf 400RWHP
Old Apr 12, 2006 | 06:38 AM
Metal Heart
Yeah, I was planning on going from the kit + Walbro... to the UTEC + Return fuel kit + aqua mist (think bigbri's setup for stock block power) to make 500ish whp.
But I simply won't have the cash for anything beyond the tt kit and walbro up front.
So I can get around 400whp with the walbro and a decent tune? That's awesome. Thanks guys. I dunno if I'll run 400... maybe 370 to be safe. I want the motor to last haha.
Old Apr 12, 2006 | 07:02 AM
Metal Heart
Yeah I plan on challenging the stock block quite a bit
I think if bigbri could do 500whp on 91 octane with a TT + aquamist and a Unichip. A UTEC, aquamist and 93 octane could do the same. But alas, this will all come later this summer.
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
