Forge Actuators on APS TT Kit
Old Apr 13, 2006 | 09:00 AM
phunk's Avatar
phunk
CJ Motorsports
Default Forge Actuators on APS TT Kit
If you are running the Forge Actuators with your APS TT kit, please let me know if you used the Green or Yellow springs, about how much actuator rod preload you set, and what your minimum boost is.
I was able to change the actuators in a customer's car without taking out the engine or turbos or anything.
The guy at Forge recommended I used the yellow springs with a little preload for a min boost of 9psi. But we also are increasing the exhaust size on this car. The last thing I want is to put this all back together and end up with a min of 14psi or something.
I would prefer the car to run 8-9min and be able to go up to 14psi. It will be very costly for the customer if I have to do this twice, so I am looking to see what other people have done and achieved with these components.
If a shop installed it for you and you are unsure of what springs and preload, please let me know which shop did it for you so that I can contact them.
Thanks.
Old Apr 13, 2006 | 09:34 AM
failsafe306's Avatar
failsafe306
GRD did mine. They were supposed to be 12psi min, but they're more like 9psi min, so I guess I got the yellow ones. Try asking Tuan.
Old Apr 13, 2006 | 10:29 AM
marluci7's Avatar
marluci7
Talk to Ted @ Scott performance.... (408)988-2233
Old Apr 13, 2006 | 06:47 PM
tig488's Avatar
tig488
do you need the psi vs color codes?
Old Apr 14, 2006 | 12:49 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
We installed the green springs (5-10psi) on one APS TT car, and tightened the rod down almost all the way. Achieved about 8.5psi. I would go with the yellow springs, which are 9-15psi, and tighten the rod about halfway, if you are looking for about 11-12psi.
Old Apr 14, 2006 | 01:18 PM
phunk's Avatar
phunk
CJ Motorsports
thanks guys
i pu them in just after my first post, i used the yellow springs and out about 1/10th an inch of preload on the lever. we will see what she does!
Old Apr 14, 2006 | 03:05 PM
Sharif@Forged
Forged Performance
Nice, that should give you about 9-10psi, I reckon.
Old Apr 14, 2006 | 03:10 PM
Julian@MRC's Avatar
Julian@MRC
Per side..We achieved almost 21psi at one point with these actuators..We were running consistant 14.5 psi most of the time.
Old Apr 14, 2006 | 03:21 PM
Sharif@Forged
Forged Performance
Then there was definately something else causing that. Wasnt this during the time of experimentation with the APS boost control solenoid, triggered with the UTEC?
The yellow Forge spring is a 9-15psi spring, depending on preload. You might see a little bit more with 3.5 inch downpipes and 3 inch exhuast.
Old Apr 14, 2006 | 03:35 PM
Julian@MRC's Avatar
Julian@MRC
We had a custom actuator made from Forged prior to them getting the APS ones in stock..We definitely got a spike whn we played with the APS actuator, which never worked out the way we planned. We saw 21psi on the boost guage and best believe we got out of it FAST!! Whatever the case, the springs in the actuators held 18.5 psi during testing with a manual boost controller..We were getting 12 psi out of the stock actuators just for reference.
Old Apr 14, 2006 | 03:38 PM
Sharif@Forged
Forged Performance
^^That explains it^^^
Old Jun 15, 2007 | 11:58 PM
DRE350's Avatar
DRE350
I received my Forge Actuators today. They have a circular green sticker on them. I'm assuming this means they have the green springs? I orderered the yellow ones but don't want the hassle of sending them back and waiting for another set (I'm from Aus). Will I be able to run min 9PSI and max 14 PSI with these?
EnjukuRacing
Sep 30, 2015 06:55 AM
