Mystery Part/Piece Found Under My Blown Motor?
Old Apr 23, 2006 | 04:53 PM
BrianLG35C's Avatar
BrianLG35C
Default Mystery Part/Piece Found Under My Blown Motor?
Hey Guys,
This is what I found underneath my baby once she laid to rest for the final time. Does anyone know what this could possibly be?
Any guesses? Just curious.
Old Apr 23, 2006 | 06:07 PM
backagain's Avatar
backagain
flux capacitor mounting bracket ,
i have no idea,
Old Apr 23, 2006 | 07:22 PM
g356gear's Avatar
g356gear
A portion of the upper oilpan. The gasket RTV sealant is the giveaway.
Old Apr 23, 2006 | 07:29 PM
BrianLG35C's Avatar
BrianLG35C
Thanks, it seems like it had to be pretty violent to blow a piece of my motor off like that. You can see on one section that it was just torn off what ever it was secured to!
Old Apr 23, 2006 | 07:31 PM
BrianLG35C's Avatar
BrianLG35C
Ok, thanks. Can that give any clues to where damaged occured in or approximate to the motor or probably not?
Old Apr 23, 2006 | 09:09 PM
overZealous1's Avatar
overZealous1
no way to tell exactly what part of the motor it came from exactly, but i agree it is part of the upper oil pan area. i'm sure you want to hear good news, but when a piece of the block is laying on the ground, it usually means you are starting from scratch my friend.
Old Apr 23, 2006 | 11:30 PM
G352NV's Avatar
G352NV
Wow your fugged. You'll need a long block.
Old Apr 24, 2006 | 12:38 AM
6swhite350z's Avatar
6swhite350z
its a beer bottle opener
Old Apr 24, 2006 | 05:38 AM
BrianLG35C's Avatar
BrianLG35C
That's what I was afraid of.
Old Apr 24, 2006 | 06:24 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
there is a chance that the majority of the trauma to your motor is on the bottom side of the block...if the piston/rod let go downward and punctured the block/oil pan immediately, this could have saved your heads
When I blew a motor a few years ago, the piston exploded and bounced around inside the cylinder for a split second, making the cylinder head look as though someone took a chisel to it
When goingdeep blew his motor, the rod came through the side of the block immediately, seized the motor, and his heads were completely unharmed!
Oh, and I've torn apart many a motor, and I can't picture which part of the upper oil pan that piece belongs to..when you pull your motor and have it disassembled, please reveal where that came from, out of curiosity for us all
Good luck
TODD
Old Apr 24, 2006 | 06:32 AM
BrianLG35C's Avatar
BrianLG35C
Good luck
TODD
Thanks for the positive spin Todd and I will post for sure once the build begins.
Old Apr 24, 2006 | 09:24 AM
t32gzz's Avatar
t32gzz
It actually looks like a piece of the stock oil pump to me. Not that it helps to know with that kind of damage.
Old Apr 24, 2006 | 02:26 PM
g356gear's Avatar
g356gear
I am looking at it again and I think possibly the portion of the aluminum plate that holds the rear main seal around the crank nose.
Old Apr 24, 2006 | 03:22 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
i can see the oil pump being a possibility..we should start a raffle..WHO CAN IDENTIFY THIS PIECE..you win a bent oem rod!!!
Old Apr 24, 2006 | 03:32 PM
hr2burn's Avatar
hr2burn
I like the "flux capacitor" theroy, I'm an idiot though. I thought it was something to do with the warp drive......DUHHHHHH!
Old Apr 24, 2006 | 07:07 PM
ryan350z's Avatar
ryan350z
looks like the rear main seal plate. But how would that get messed up? Take pics of the block curious minds want to know
ryan
Old Apr 24, 2006 | 10:27 PM
overZealous1
my vote is for the top rail or the upper oil pan or the bottom rail of the main block.
Old Apr 18, 2007 | 12:57 PM
BrianLG35C's Avatar
BrianLG35C
Well I finally found out, will post pics in another thread.
