Head strengthening mod
Old May 24, 2006 | 09:30 AM
  #201
Gman2004's Avatar
Gman2004
Originally Posted by tig488
oh thats not bad at all, i thought it would be much more, so they just take off the valve covers, thats all?
yep
meatbag,
don't worry I plan on giving the car a super duper fuking thrashing @16psi and I will post the results.
Old May 24, 2006 | 01:08 PM
  #202
Gman2004's Avatar
Gman2004
Default Results!
Well I went out for a late lunch and stoped to pick up my car. The only problem with the install was that they had to drain the cooling system. The shop owner told me that when they losened one of the bolts the fluid started coming out. It was either drain it or allow fluid to get into the oil. What ever I didn't understand WTF he was talking about and really didn't care cause the car was done and they refilled the cooling system with royal purple ice and distilled water.
Now for the results. I got in the car, started it, and looked at the temp gauge. It was at 170. I guess they took the car around the block to check for leaks so it was still warm. I was rather close to the freeway so I turned up the boost to 16psi and took the back roads toward the freeway. I immediately started to beat the chit out of the car. I beat the *** out of it through all the gears. When I got on the freeway I redlined every gear through 5th and some of 6th. My temp gauge never went past 200. In fact most the time it stayed at 190 until I would come to a stop at a light and then it would rise to 200. As soon as I started moving again the needle would drop back to 190. When I parked the car I did notice the overflow tank was full and a little coolant on the radiator by the overflow, but maybe this could have been because I had air bubbles in the system from when it was refilled? Either way the car didn't overheat! I will continue to flog it and let you all know how it holds up. BTW, It was 90 degrees outside with 63% humidity.
Old May 24, 2006 | 01:12 PM
  #203
three_fifty_z's Avatar
three_fifty_z
Get some videos up of your acceleration at 16PSI
Old May 24, 2006 | 01:13 PM
  #204
three_fifty_z
Thumbs up
P.S you have one sick G
Old May 24, 2006 | 01:18 PM
  #205
meatbag's Avatar
meatbag
Not quite what i wanted to hear, hopefully you just need to work some air bubbles out.
Old May 24, 2006 | 01:21 PM
  #206
Gman2004's Avatar
Gman2004
I think it might be bubbles because they filled the system up in 5 minutes.....no bleeding done. I wasn't worried about it cause my greddy breather tanks takes care of the bleeding. We'll see. Either way before the bolts I could not go through the gears like I did with out my temps going up to 230 degrees or higher. I never went above 200 degrees with the bolts.
Old May 24, 2006 | 01:22 PM
  #207
overZealous1's Avatar
overZealous1
this was never intended to be an end all to the combustion leaking problem, only designed to help this one area. o-ringing, upgraded head studs, and this mod though will definately lessen the chances of running into it though.
Old May 24, 2006 | 04:03 PM
  #208
meatbag's Avatar
meatbag
I understand that, i was hopeing he would see the same improvement like you got. I am still not doubting it though.
Old May 24, 2006 | 05:54 PM
  #209
Gman2004's Avatar
Gman2004
I definately have air in the system. I turned on the heater and it came out cold. I filled the system with some more distilled water as the car ran with the heater on. I bleed a bunch of air, but I still have some left. Eitherway, air bubbles and all in the system the fuking car doesn't overheat during 16psi freeway runs!
Old May 24, 2006 | 06:14 PM
  #210
meatbag's Avatar
meatbag
Anyone tried to see what it would take to get new heads made from billet so we dont have to screw with the cheap oem heads?
Old May 24, 2006 | 08:21 PM
  #211
overZealous1
well i'm guessing performance motorsport would have the program to run a set off, but oh boy i bet it would be a pretty penny!!
Old May 25, 2006 | 07:49 AM
  #212
theking's Avatar
theking
Might as well have them run the program for the billet block afterwards,
Old May 25, 2006 | 08:06 AM
  #213
MIAPLAYA's Avatar
MIAPLAYA
I heard our buddies from down under already did this...
Old May 25, 2006 | 09:27 AM
  #214
meatbag's Avatar
meatbag
Ive been talking to a couple places about getting billet block/heads made but havent had that much luck yet. No one seems to want to take the project on. I still need to call Performence Motorsport and see what they say. Anyone else know who i can contact?
Old May 25, 2006 | 08:18 PM
  #215
overZealous1
anyone else that is pushing more than 1300hp in the Vq35, lol. are you using the car for strictly drag racing? if so, i would just fill the block and heads with block fill. if you are trying to get someone to machine out heads and a block and still have cooling passages, it will be nearly impossible, or at very least, a machining marvel.
Old May 26, 2006 | 10:06 AM
  #216
meatbag's Avatar
meatbag
IM looking for someone that can do the cooling passeges too. I found one shop, but they said that they are not accepting new projects for another 6 months
Old May 27, 2006 | 12:25 PM
  #217
failsafe306's Avatar
failsafe306
I recieved my replacement stud today...thanks Scott.
Old May 27, 2006 | 12:34 PM
  #218
Quamen's Avatar
Quamen
I would bet that the price of a billet block and heads would greatly outway the cost of doing the necessary mods to the stock parts to get them to hold near 1500whp. With all of the strengthening mods out there now I don't believe that we have anyone with all of them yet. I could be wrong though.
Old May 27, 2006 | 03:37 PM
  #219
meatbag's Avatar
meatbag
I think even with everything thats out right now anything over 900whp is going to cause some problems
Old May 27, 2006 | 05:15 PM
  #220
Quamen's Avatar
Quamen
meatbag:
what areas do you think problems will arise in? The heads?
