Head strengthening mod
Old May 19, 2006 | 01:18 PM
  #161
failsafe306's Avatar
failsafe306
Got mine today, thanks! Looks like I'll be installing these tomorrow; can't wait.
Old May 19, 2006 | 02:19 PM
  #162
meatbag's Avatar
meatbag
Originally Posted by overZealous1
i used a figure of 1/8th turn after touching bottom on the stud. this is basically to clear the rough sand casting and create a more solid seating surface. the large nut gets torqued to 50ft lbs and is a 1 1/16" socket iirc.
Oh duh, im dixlexic
Old May 19, 2006 | 02:43 PM
  #163
ryan350z's Avatar
ryan350z
got mine going into the garage and gonna have some fun tomorrow
Old May 19, 2006 | 03:14 PM
  #164
overZealous1's Avatar
overZealous1
ok, it is confirmed now. my water loss was just due to the high heat here lately. it has been 65-70 here the last 24 hours and i have put about 200 miles on the car. havn't lost a drop.
Old May 19, 2006 | 07:39 PM
  #165
ZU L8R's Avatar
ZU L8R
Viper Sellout
they are in there very tightly. they lock due to the seal they make with the stainless sealing washer. if you are using the perfect size allen wrench, you should have no prob. but yes they are in tight and no they are not left hand thread. if you are using a allen socket for a 3/8" drive, it would be way easier.
Using a 5/16 allen socket on a 3/8 drive can't budge any of them. God Damnit all the things that are suppose to be easy always turn out to be a pita!
Old May 19, 2006 | 08:55 PM
  #166
Gman2004's Avatar
Gman2004
I received mine today.
Old May 20, 2006 | 09:09 AM
  #167
overZealous1
lol. torque is stored, so keep trying, they will come. it is kind of a knuckle buster though, because it takes alot of force to "unlock" them, but will come out like butter after the first 1/10th of a turn.
again, just undo one at a time with the rad cap on, and you will not lose any water.
Old May 20, 2006 | 11:27 AM
  #168
ZU L8R's Avatar
ZU L8R
Viper Sellout
My motor is not even in a car. I have all the room in the world to work with, they won't budge!!!
Old May 20, 2006 | 12:29 PM
  #169
ZU L8R's Avatar
ZU L8R
Viper Sellout
I'm so fuked. Tried a 7mm allen socket too. Same result, 0 for 4. I hope an easy out works cause thats about my only option left that I can think of.
Old May 20, 2006 | 01:53 PM
  #170
ZU L8R's Avatar
ZU L8R
Viper Sellout
I meant 8mm
Old May 20, 2006 | 04:02 PM
  #171
overZealous1
dam, not sure what the prob your having is. i undid 2 different sets of heads fine. all at ambient temp like yours is. like i said, torque is stored so on hard to undo bolts, keep constant hard pressure for about 5 seconds, then one quick tug. makes it so you have far less chance of stripping it.
Old May 20, 2006 | 04:10 PM
  #172
failsafe306
Well I got 3 of the 4 in correctly. The one on the rear passenger side wouldn't go down all the way; the thread on that one was kinda chewed up in one spot but didn't look too bad. Well, about halfway down, it stuck, and I can't get it out because if I put anymore torque on it, it starts to break apart the slot in the stud.
Oh well, at least the other three went in perfect.....I'm kicking myself for not fixing that stud before installation.
Old May 20, 2006 | 05:20 PM
  #173
overZealous1
if it is sticking up high enough, use 2 of those nuts to double nut the stud and it will easily come out.
Old May 20, 2006 | 06:21 PM
  #174
failsafe306
There wasn't enough to get two of those massive bolts on, lol.
Old May 21, 2006 | 02:57 PM
  #175
ryan350z's Avatar
ryan350z
Failsafe try a screwdriver bit that is what I used to install mine. I got the bit from snap on and I had zero problems getting it in. Scott those nuts were huge. well go big or go home right? Almost got this engine back in the car just waiting on my valve buckets.
Zu L8R I had to use some force to get out those bolts as well. What you might want to try is to use a pipe on the end of the rachet to get more leverage and give that a try. Good Luck
Ryan
Old May 21, 2006 | 03:18 PM
  #176
ZU L8R's Avatar
ZU L8R
Viper Sellout
Ryan
I tried it and there all stripped now. Gonna try drilling and easyouts next. Should be fun. Stupid **** always happens to me
Old May 21, 2006 | 03:28 PM
  #177
ryan350z's Avatar
ryan350z
might be able to so up in size to a SAE size maybe 3/8ths and tap it in with a hammer to get a tight fit and back it out that way. This stuff always happen to me before I got old and wise lol. Good luck let us know how it turns out.
Ryan
Old May 21, 2006 | 03:30 PM
  #178
Julian@MRC's Avatar
Julian@MRC
Dont do that..You will get metal shavings in your combustion chamber and damage your motor.
Old May 21, 2006 | 06:55 PM
  #179
captj3's Avatar
captj3
What about using a impact gun or ratchet? Would this be advisable?
Old May 21, 2006 | 07:40 PM
  #180
ZU L8R's Avatar
ZU L8R
Viper Sellout
I was gonna have a vac going the @ the same time I'm drilling. I'll try vice grips first but I don't know if I get enough of them to grip.
